Can Just Adding New Electric Wiring For New Outlets Increase Power Usage? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 10:36 AM   #31
Learning by Doing
Leah Frances's Avatar
Both cooking meth and growing marijuana would account for dramatically higher electric bills.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following 2 Users Say Thank You to Leah Frances For This Useful Post:
Code05 (09-21-2011), gregzoll (09-21-2011)
Old 09-21-2011, 11:07 AM   #32
Tileguy
Bud Cline's Avatar
Rewards Points: 558
LMAO
Seems this thread is now headed south.
Old 09-21-2011, 11:40 AM   #33
Code05's Avatar
Rewards Points: 1,104
Well, if we are go that route: the hot plate set at 180F for my homemade still uses a consumption rate of..... Never mind, I ain't telling.
Code05 is offline   Reply With Quote
Old 09-21-2011, 12:19 PM   #34
Originally Posted by Daniel Holzman View Post
If you don't have an ammeter, you can check the draw of each circuit by turning off all breakers but one, and noting if the meter increases. The meter should be stationary if there is nothing plugged in, clearly if the meter is advancing, there is power consumption, and the technique I just described can be used to isolate the circuit, and eventually the offending device.
I don't mean to hijack the thread, but when I've investigated a similar issue I've come across a problem with "smart" meters that do not have anything to observe spinning. The only indication of electrical usage is when the kWh number advances by one. Even for something with a 1A draw you'd be waiting at the meter for 10 hours to see if anything was happening. Good luck if you have a 200mA ground fault or something. Is there anything people with these "smart" meters can do other than purchasing an ammeter? I'm hoping there's some trick to these meters to see electrical activity.
BobSmitt is offline   Reply With Quote
Old 09-21-2011, 12:29 PM   #35
I=E/R
a7ecorsair's Avatar
My digital smart meter as a blinking bar that steps across to mimic the rotating dial of old meters
a7ecorsair is offline   Reply With Quote
Old 09-22-2011, 04:37 PM   #36
Thank you. I hadn't noticed those little dots at the bottom of the display before. I can't find any documentation of what those dots signify exactly for this exact meter, but it seems from others like each dot is probably 1Wh. In that case my meter, an OpenWay CENTRON, appears to give 6Wh for every "rotation" of the dots.
Code:
___ 0 Wh
*__ 1 Wh
**_ 2 Wh
**> 3 Wh
_*> 4 Wh
__> 5 Wh
___ 6 Wh
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 03:52 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 07:12 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
