Can I Wire A Range Hood To An Exhisting Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2006, 05:39 PM   #1
Smile
Can I Wire a range hood to an exhisting outlet?
I just bought a basic $40 range hood that vents into the kitchen. The wall that I need to put it on has two switch/outlets and one outlet recepticle.
One switch controls the Garbage disposal and the other controls the overhead lights in the kitchen.
Is there a way of hardwiring into the exhisting outlet/swith light so I can get power to this range hood?
Also, the old range hood circa 70's was hardwired through the ceiling near the center of the kitchen. Can I possible tap in that wiring because the old hood has been taken out and the wires have been capped.
Thanks.
skellies is offline   Reply With Quote
Old 05-08-2006, 09:50 PM   #2
Can't you just hard wire like the old on was hard wired? And how were these old wires made safe after you removed the old hood?
Don't tie it in with your disposal, because that is supposed to be a dedicated circuit, tying it in with your kitchen lights is fine unless it is a microwave/range hood combo, then you'll need a dedicated circuit.
Sparky Joe is offline   Reply With Quote
Old 05-09-2006, 05:06 PM   #3
Sparky raises a good quesion, how did you make it safe when the former one was removed? What was the previous setup?
1crazygirl is offline   Reply With Quote
range hood vent vinman Roofing/Siding 6 05-07-2012 02:23 PM
duct a range hood into garage? jimb317 General DIY Discussions 8 01-30-2008 08:41 PM
Range outlet required? Doug_Shaver Electrical 2 06-12-2007 06:10 PM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 11:18 PM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 10:04 PM
