Old 05-31-2011, 11:52 PM   #1
Can I wire like this?
Can I wire my lights like this? Will I get any voltage drop or weird shenigans?
Please advise.
edta1 is offline   Reply With Quote
Old 06-01-2011, 01:11 AM   #2
Electrician
SD515's Avatar
In your drawing, the source jumps the left and the center rows, and would only power the right row. If you want all of them run off one switch try something like one of these...
Kyle
Old 06-01-2011, 07:24 AM   #3
Electrical Contractor
kbsparky's Avatar
Please advise.
Voltage drop? Yes (although negligible).
Weird shenigans? Not exactly sure what a shenigan is, maybe you are thinking of a shenanigan? Yes as well, since only 2 of the lights in your diagram as shown will actually work.
I'd rethink the circuit as shown by SD515
-KB
Old 06-01-2011, 07:47 AM   #4
The original diagram is technically correct.
Some experts and electrical engineering professors insist that for the original diagram large dots (see next diagram), which incidentally correspond to wire nuts, be placed over the intersections of the lines that are not jumpovers.
For ordinary ceiling recessed lights (can lights) there is usually not enough room in the small junction boxes accompanying the lights. Separate larger junction boxes, with accessible covers and somewhat suggested by the original diagram, would be needed to contain all of the wires coming together.
The third diagram above is a method of avoiding the need for extra junction boxes. As with the previous diagrams, connect all the black wires together and, in separate bundles, connect all the white wires together.
If you cut too many corners for convience's sake then you may get shenigans.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-01-2011, 08:20 AM   #5
I=E/R
a7ecorsair's Avatar
a7ecorsair is offline   Reply With Quote
Old 06-01-2011, 08:23 AM   #6
Ooops! It was late last night when I posted. Sorry for the wrong diagram. I meant to wire like SD515 (first picture).
I'm going to try to squeeze everything in. I really hope I don't need an extra junction box per light. I'm just sick of drilling through joists right now to wire it like SD515 2nd picture.
Old 06-01-2011, 08:27 AM   #7
Licensed electrician
Having 3 cables in the built-in junction box should not be an issue.
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
