Can I Use Recessed Light Wiring For A Regualr Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 06:57 PM   #1
Can I use recessed light wiring for a regualr light?
I have (one) recessed light in my covered entry outside and I want to replace it with a regular light. I removed a portion of the mounting frame and can modify it to hold the fixture. I am concerned about the ground wire that came with the light I am going to install. I am assuming that the armored cable from the recessed light will serve as the ground. If that's so what do I do with the ground wire attached to the light fixture? Can I even use the same wiring? Thanks...Brett
integrity634 is offline   Reply With Quote
Old 03-18-2009, 07:29 PM   #2
First, if there is enough slack in the existing feed, try to remove the old fixture and install a new jbox and mount your new fixture on that.
If that's not gonna work, run a short piece of cable from the old fixture jbox to a new jbox and mount the new fixture on/over that.
Do something smart with the ground. You could use a cable with a ground to the new jbox and secure the ground wire adaquately in the old jbox.
220/221 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
recessed light farrington135 Electrical 3 12-03-2006 01:02 PM
