-   -   Can I use recessed light wiring for a regualr light? (http://www.diychatroom.com/f18/can-i-use-recessed-light-wiring-regualr-light-40625/)
integrity634 03-18-2009 06:57 PM
I have (one) recessed light in my covered entry outside and I want to replace it with a regular light. I removed a portion of the mounting frame and can modify it to hold the fixture. I am concerned about the ground wire that came with the light I am going to install. I am assuming that the armored cable from the recessed light will serve as the ground. If that's so what do I do with the ground wire attached to the light fixture? Can I even use the same wiring? Thanks...Brett
220/221 03-18-2009 07:29 PM
First, if there is enough slack in the existing feed, try to remove the old fixture and install a new jbox and mount your new fixture on that.
If that's not gonna work, run a short piece of cable from the old fixture jbox to a new jbox and mount the new fixture on/over that.
Do something smart with the ground. You could use a cable with a ground to the new jbox and secure the ground wire adaquately in the old jbox.
