Can I Use This Outlet For A Split Outlet?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 01:50 PM   #16
Julius793's Avatar
Originally Posted by Audiotekm
Seems to work. So the 2 cable runs to one outlet one is from the electrical box asnd the other one is a loop through to a second outlet? And what does that "tab" do?
To much beer someone else hopefully will answer
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-22-2012, 01:52 PM   #17
jproffer's Avatar
Rewards Points: 702
I think we're talking about 2 different things here.
The receptacle you have pictured in post 9 can be a split receptacle if you break the tabs out.
The receptacle that your link shows in the OP and in post 13, can NOT be a split receptacle because there are no tabs to remove.
jproffer is offline   Reply With Quote
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 10:46 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
