Old 01-19-2012, 12:52 PM   #1
Can I use this outlet for a Split Outlet??
I'd like to replace an old outlet in my kitchen with one of those but I don't think it's possible.
http://www.smarthome.com/4534W/Levit...abaster/p.aspx
Audiotekm is offline   Reply With Quote
Old 01-19-2012, 01:01 PM   #2
Missouri Bound's Avatar
I looked at the specifications...it doesn't appear that you can seperate the outlets...so it's NOT possible, as you though.
Old 01-19-2012, 01:03 PM   #3
OK thanks
Old 01-19-2012, 07:44 PM   #4
You could if it was downstream from a gfci recep. I.e. home run into gfci on line side load side wire to the next recep. You are allowed to put 15a receps on a 20a line. Kit requires at least 2 appliance circuits.
Knauer is offline   Reply With Quote
Old 01-19-2012, 08:20 PM   #5
Huh?
Old 01-19-2012, 09:39 PM   #6
jproffer's Avatar
not sure which one, but one of us needs a
jproffer is offline   Reply With Quote
Old 01-20-2012, 01:47 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Are you in USA or Canada ? that will make the differnce on that part and second thing ., The Acenti receptale IIRC they are not splitable.
Merci,
Marc
Old 01-20-2012, 08:31 AM   #8
Licensed electrician
The PDF only appears to show 3 connections, H N and G. The receptacle must have internal bussing to connect all 3 receptacle slots, not the two screws with a tab between them.
Old 01-22-2012, 12:30 PM   #9
What about with this wiring? There's 2 cable runs on that outlet but the new one only has 3 screws (Hot, neutral and ground) can I tap all the hot on the hot screw and the neutral on the neutral screw?
Old 01-22-2012, 12:56 PM   #10
Julius793's Avatar
No only one wire per screw, so just pigtail it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-22-2012, 01:18 PM   #11
OK thanks but all the Hot and Neutral can be on the same screw as long as it's not more than 1 wire per?
Old 01-22-2012, 01:22 PM   #12
Julius793's Avatar
If you have multiple screws one one side that's fine assuming the tab isn't broken
Old 01-22-2012, 01:32 PM   #13
It's for that outlet and there's no tab just the 3 screws http://www.smarthome.com/4534W/Levit...abaster/p.aspx
Old 01-22-2012, 01:40 PM   #14
Julius793's Avatar
So pigtail it, am I missing something?
Old 01-22-2012, 01:49 PM   #15
Seems to work. So the 2 cable runs to one outlet one is from the electrical box asnd the other one is a loop through to a second outlet? And what does that "tab" do?
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 10:46 PM
Adding Ceiling Light From Switched Outlet vboz5 General Discussion 2 03-04-2009 01:53 PM
