Can I Use A Marine Battery Charger On UPS Gel Cells? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 05:50 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Can I use a marine battery charger on UPS gel cells?
I have a couple old UPS batteries lying around that I don't really trust for actual UPS use as they are old and probably wont hold a charge very long, not to mention they are normally best in pairs. They still work, so I'm thinking of just having them handy for during power outages I can hook up 12 volt items such as lights (which I need to find next time I go to the hardware store, or automotive store).
Could I use a charger like this on such batteries:
http://www.canadiantire.ca/AST/brows....jsp?locale=en
They are sealed lead acid gel cells. I can't see why not, as they are basically smaller and sealed versions of marine batteries, from what I understand.
Red Squirrel is online now   Reply With Quote
Old 03-23-2011, 05:55 PM   #2
Experienced
Jackofall1's Avatar
I thought this was an old post brought back to life, but, it looks and smells new to me.
Why not, as long as the voltage is correct.
Mark
Old 03-23-2011, 06:43 PM   #3
Wire Chewer
Rewards Points: 46
That's what I figured. 12v is pretty much the standard while some have a selector. Handy to have if the car wont start, too. :P
Old 03-23-2011, 10:06 PM   #4
If they're really AGM or Gel and not just deep cycle lead-acid, you should really get a charger designed to handle AGM/Gel batteries. They charge a little different than regular lead-acid. We use these: http://www.batterychargers.com/Produ...tName=94026842
We use those kind of batteries all the time at work (live theatre) for powering lights on moving set pieces and such.
ihildreth is offline   Reply With Quote
generator battery trickle charger veretiL Electrical 5 09-08-2010 06:51 PM
How to connect my battery to my solar charger? rdlrn19 Green Home Improvement 0 02-26-2010 06:30 PM
Trickle charger on portable generator - bad battery? timp Electrical 5 01-01-2009 08:46 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 02:11 PM
modify battery charger geeyathink Electrical 1 08-03-2006 05:36 AM
