Old 08-24-2010, 12:51 PM   #1
Can I use lights and outlets on same circuit?
I have an old house. There are two 12-2 wires going into the garage. One is on the same circuit as the kitchen outlets with 20 amps. The other is a 12-2 that goes directly to the panel. I want 2 lights and 4 outlets (two for the two garage door openers) in the garage. What is the best way to do this with what I have. Due to drywall, it would be very hard to run a 14-2 to the panel from the garage for the lights.
Thanks for any input.
heyd is offline   Reply With Quote
Old 08-24-2010, 12:57 PM   #2
Xtreme DIY'r
Where are you located ?
Attached garage ?
These days kitchen outlets can't leave the kitchen
So not a good idea to add onto that, against code
So I would use the other 20a circuit, use 12g wire
Yes its OK to have outlets & lights on the same circuit
Of course the problem is if you are using a tool & kick the breaker off your lights go off
Old 08-24-2010, 01:01 PM   #3
I'm from MA. House is 1930's attached. Ok, I'll terminate the kitchen wire and I'll run it all off the other line. Should I use a 20 or 15amp breaker? Also, should I run 12-2 to the lights and light switch?
Thanks!
Old 08-24-2010, 01:03 PM   #4
Xtreme DIY'r
If the existing wiring is all 12g then use a 20a breaker
Use 12g wire for the lights
If there is any 14g then you have to use a 15a breaker
Old 08-24-2010, 01:05 PM   #5
awesome. Thank you!
All the lights and Outlets on one Breaker? jonathan03 Electrical 7 03-15-2010 01:30 PM
Lights on circuit with outlets Klawman Electrical 16 02-22-2010 07:51 AM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 09:54 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
How many lights on a circuit? How many outlets? helpless handyman Electrical 4 04-14-2008 01:11 PM
