Can I Use Existing Wire For New Purpose? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 05:40 PM   #1
can I use existing wire for new purpose?
When I first moved into my house it was heated with electricity, I put in a gas furnace, now I have a 200 volt panel with lots of unused circuits. Can I use the wires that supplied the baseboard heaters for duplex outlets if I run a new neutral wire to those new outlets?
schlitzi is offline   Reply With Quote
Old 10-09-2009, 08:03 PM   #2
joed's Avatar
Rewards Points: 11,576
You can not run a neutral wire separate from the cable. If the cable has a white wire in it you can use the same cable and reconnect it in the breaker panel for 120 volts. There must also be a ground present.
Old 10-11-2009, 02:27 PM   #3
There is a black wire and a red wire and a ground, can I do anything with these cables? How about if I label them hot and neutral?
Old 10-11-2009, 02:33 PM   #4
A red & black can't be remarked for use as a neutral
The neutral must be white in color
The ground can not be used as a neutral either
Old 10-11-2009, 08:20 PM   #5
" Euro " electrician
frenchelectrican's Avatar
If this OP is from Cananda the rules will be little diffrent due the Cananda did have straght 240V NM aka Red NMD90
here what it look like I know the photo may look small
That used for straght 208 or 240 volt load sans netural at all
Merci,Marc
Old 10-11-2009, 08:23 PM   #6
His IP is from Canada
Does Canada allow using black or red as a neutral on a 120v line?
Old 10-11-2009, 08:27 PM   #7
I just can't say yes or no but I feel the same way what we remarked white conductor for 240 volt useage but I am not sure what Canada will do that way or not so I know one of our guys is from Canada he will have to answer that question direct so I don't want the readers get confused with this set up.
Merci,Marc
UPDATE: I just got a hold of my Canadaian electrician freind and he say no you can not remark the red NMD90 conductors at all.
Old 10-11-2009, 09:28 PM   #8
joed's Avatar
The stuff is called Heatex cable.
http://www.nexans.ca/eservice/Canada..._90_C.html#top
No you can not remark one of the wires to white.
Old 10-11-2009, 09:30 PM   #9
Merci,Joed for getting the correct name of this one.
Merci,Marc
Old 10-12-2009, 07:09 AM   #10
So you guys are saying there's nothing to be done but rip it out and run new cable? Just wanted to save some money, thanks for the info.
Old 10-12-2009, 09:10 AM   #11
Rewards Points: 1,418
Don't rip it out. You could use some runs for 240 volt window air conditioners; some are more efficient than 120 volt models.
Old 10-12-2009, 11:28 AM   #12
It sounds like you need a neutral wire for everything but baseboard heaters and since I'm through with them, their coming out. Thanx again guys.
p.s. I thought the electrical codes were the same in Canada and the U.S.
Old 10-13-2009, 12:07 PM   #13
Rewards Points: 58
I would use the existing cables and remark. It's just plain silly to not use them. Mark them (Homeruns) at the panel and at the device. Then continue on with the correct colored cable. Sometimes common sense is in order.
Old 10-13-2009, 02:33 PM   #14
WaldenL's Avatar
Rewards Points: 268
If it's a trivial run then I'd re-run, but otherwise I'm with JV; seems silly to do a major rewire job if you've got usable wire. If the gauge is correct then it will work, just not according to code. It's not a fire hazard to run neutral over a red cable, the electrons don't care about the color of the insulation.
WaldenL is offline   Reply With Quote
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
How do I wire these switches? keano016 Electrical 2 10-07-2009 11:19 AM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 06:22 PM
