Can I Use This Double 15 Amp Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 04:13 PM   #1
listo's Avatar
Rewards Points: 93
can I use this double 15 amp breaker?
Can I use this double breaker as 2 single 15 amp breakers if I take out the little bar that holds the 2 switches together?
listo is offline   Reply With Quote
Old 07-09-2013, 04:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
Leave the bar in place, you can still use the breaker as 2 120 volt circuits. Only issue is both circuits go off if one trips or is turned off.
Reason I say not to remove bar is you will be modifying a UL listed device. This voids the UL listing.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
ben's plumbing (07-09-2013), listo (07-09-2013)
Old 07-09-2013, 04:20 PM   #3
listo's Avatar
Rewards Points: 93
10-4 the thanks
Old 07-09-2013, 04:53 PM   #4
Rewards Points: 6,652
That is actually a Canadian Panel, not U.S.. The clue is the "Stab-Lok" sticker if you did not notice. They have different rules up there than we do down here.
Old 07-09-2013, 04:57 PM   #5
listo's Avatar
Rewards Points: 93
Oh... Any Canadians know if I can do it then? What if I just use it as one breaker is that OK? I don't really need 2 anyway
Old 07-09-2013, 05:10 PM   #6
A "Handy Husband"
rjniles's Avatar
Did not notice and he did not say "eh"
Old 07-09-2013, 05:40 PM   #7
Just replace with two singles then.
Old 07-09-2013, 05:47 PM   #8
listo's Avatar
Rewards Points: 93
Lol then i have to go to the store.
Old 07-09-2013, 06:18 PM   #9
A "Handy Husband"
rjniles's Avatar
Have to disagree with Greg. I doubt that the CEC would not let you use half a 2 pole breaker for a 120 volt circuit. Call your AHJ (electrical inspector ) with the question.
Old 07-09-2013, 06:18 PM   #10
BTW, I thought that in Canada, only licensed professional electricians could do work on the panels, not the homeowners.
Old 07-09-2013, 06:20 PM   #11
It would be no different than down South of the border here. Problem is, that both legs are live, even though you would be using only one pole. Not a safe way to do it. You are better off either using it for a MWBC, or pulling it, and putting in two breakers, with one locked in the off position, or one breaker and a blank.
Old 07-09-2013, 10:02 PM   #12
Rewards Points: 582
the proper way is 1- don't cut the bar ...2- install 2- single breakers....so off to the store you go...ben sr...mama said if you do it do it right
The Following User Says Thank You to ben's plumbing For This Useful Post:
gregzoll (07-09-2013)
Old 07-09-2013, 10:32 PM   #13
listo's Avatar
Rewards Points: 93
Thanks guys, I figured that was the case, went to the store and completely forgot about it so I have to go again tomorrow lol oh well
The Following User Says Thank You to listo For This Useful Post:
ben's plumbing (07-10-2013)
2 Single Poles to 1 Double GFCI Breaker nuckphoto Electrical 24 11-11-2010 12:40 AM
install 60 amp double breaker with 6/2 romex darthyogi Electrical 5 10-04-2010 06:36 AM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 06:15 AM
Novice Replacing 60 amp double pole breaker Ayreonna Electrical 40 02-19-2008 02:26 AM
single vs. double breaker Neil_K Electrical 3 11-15-2004 12:02 AM
