Can I Use A Dimmer On Tube Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 06:48 PM   #1
can i use a dimmer on tube lights?
hi i wanted to know , my mom want to install that dimmer so she can reduce the light in the kitchen. but we have those tube lights install on the roof like 6 of them together so can i use the dimmer on that ? or no thanks for help
ak.89 is offline   Reply With Quote
Old 08-19-2011, 07:02 PM   #2
Master Electrician
Rewards Points: 3,874
Generally no unless the fixture has a dimming ballast, which is unlikely.
brric is online now   Reply With Quote
Old 08-19-2011, 07:17 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
As brric said, unless those tube lights (fluorescent is the more common term) are desinged to be dimmed...no, can't do it.
ak.89.....are you by any chance 22 years old?
ddawg16 is online now   Reply With Quote
Old 08-19-2011, 07:36 PM   #4
ok so in short those tube lights (or if i call floursecent) cannot be used with a dimmer.
lol why u ask that , yes i am 22.
Old 08-19-2011, 07:38 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So what does a 22 year old find to do in Alaska other than hunt and fish?
XXX
Old 08-19-2011, 11:07 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Most liner flourscent will not dim at all unless you get dimmable ballast plus controller AFAIK they are not cheap the last price I brougt one not too long ago in France it was 115 { Euros } and there are few verison of dimmable flourscent ballast.
However if you have screw in CFL some will work fine with dimmer only if marked to work with dimmer or say dimable.
What wattage the bulb you have on them { and length as well }
Merci,
Marc
Old 08-20-2011, 07:34 PM   #7
JOATMON
ddawg16's Avatar
Because your typing is typical of the young 'texting' age....void of proper grammer and use of capital letters....or rather, lack of....
Not a flame on you...just an observation....something to be aware of as you get into a profesional work enviornment....guys with MBA's tend to put a lot of weight on how people communicate.
4 way dimmer jamiedolan Electrical 7 08-24-2010 12:45 AM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 07:23 AM
Recessed lights swith dimmer at end bphyatt Electrical 6 01-03-2010 09:47 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
