Can I Use 600v Wire To Connect 120v Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 02:51 PM   #1
Can I use 600v wire to connect 120v outlets
I am repairing an old Victorian. I had to remove a chandelier to fix the ceiling and now I have problems. I think the wiring is knob and tube the chandelier was obviously a swag lamp someone spliced in. The pig tail was made from a hunk of lamp cord. The main wire is slightly frayed. I plan to wrap the main wire in a couple layers of black electrical tape. I want to replace the hunk of lamp cord, but the wire I bought says 600v 14AWG The outlet fixtures all say 120v 15amp. Can this wire be used for the pigtail or is it too big?The house wires are all 14 gauge.
Patricia54 is offline   Reply With Quote
Old 01-08-2011, 02:56 PM   #2
600v is the max rating
15a = 1800w = #14g wire min
If the wire is frayed you are better off replacing it
Tape is not meant to relace the wire insulation
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Patricia54 (01-08-2011)
Old 01-08-2011, 03:32 PM   #3
Thanks Scuba_Dave,
I'd like to replace all the wiring but can't. The fray is only at the end, but if it frays any more I'll be stuck. Here are the details: The wire is coming through a small hole in the lath. there is about 1/3 inch of this visible piece that has sound insulation and about 1 1/4 inch of bare wire below that. If I tape around the sound fabric and trim off the frayed edges, I have enough to hook the pigtail to. I thought about using a heat shrink sleeve to slip up the wire, but I wouldn't be able to apply heat to the part of the sleeve that is inside the lath plus the guy at Lowe's said that the sleeves have a dubious insulating value.
Old 01-08-2011, 03:54 PM   #4
So this wire which is 14 gauge and also says 1000v is not sufficient? 600v is a lot bigger than 120v so that is confusing. Should I be able to find a 14 gauge wire that goes to 1800v? The only other wire in this electrical dept. was auto wire.
Old 01-08-2011, 04:00 PM   #5
DIY staff
Rewards Points: 7,174
You are confused---14 gauge is fine for a 15 amp breaker. don't worry about the volts--
Old 01-08-2011, 04:03 PM   #6
1800w = watts, ....not v = volts
Tags
gauge , light fixture , wiring
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
where to connect ground wire mleee999 Electrical 1 12-11-2009 03:17 PM
240v appliances with 120V outlets raevenbox Electrical 21 07-02-2009 12:05 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
