Can I Use 3 Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 09:37 PM   #1
listo's Avatar
Rewards Points: 93
can I use 3 wire?
I need to run a line of my breaker box, I only need a 2 wire but all I have left is 3 wire, can the 1 wire just hang out not connected to anything?
listo is offline   Reply With Quote
Old 02-14-2013, 09:42 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
It will work if thatís all you have. Kinda a waste but if you are not going to use it for anything else you might as well use it.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
listo (02-20-2013)
Old 02-14-2013, 09:48 PM   #3
listo's Avatar
Rewards Points: 93
K thanks, I don't think I'll use it for anything else, maybe it's worth it to just grab a 40 ft chunk of 2 wire
The Following User Says Thank You to listo For This Useful Post:
rrolleston (02-15-2013)
Old 02-15-2013, 09:36 AM   #4
joed's Avatar
Rewards Points: 11,572
Cap the wire and leave it in the boxes. Don't cut it off. It may be useful in the future.
The Following 2 Users Say Thank You to joed For This Useful Post:
J. V. (02-15-2013), listo (02-20-2013)
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
