Can I Use A 20amp Outlet Receptical On A 15amp Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 09:47 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by chris75 View Post
Sorry nap, switches are rated by load... so I can install 15 amp switch on a 20 amp circuit. So as long as the load is not more than the switch is rated for.
Check out 404.14 (A)
Yes, you are correct but let me add this:
a switch is rated for the load but since the circuit is what limits the load (ultimately) I prefer recommending a switch rated for the circuit since I have no idea what the installer is going to install on that switch.
Fair enough?
Yes, it goes above what the code allows but since when is the code the upper limit of what we can install?
Old 01-18-2009, 09:54 PM   #17
Electrician
Fair enough?
I see your logic.
chris75 is offline   Reply With Quote
Old 01-18-2009, 09:57 PM   #18
Good information from both on this topic
Thanks for the info & code reference to look up
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 01:10 PM
