Can I use a 20amp outlet receptical on a 15amp circuit?
I have a power strip I need to configure and it has a t plug on it like this one: http://cache.smarthome.com/images/4541w.jpg
(the power strip itself wont be using more than 1 amp, as I will have nothing plugged into it.)
I can I replace my 15amp receptical with a 20amp one, or is that generally a no no?
I dont think that a light switch would matter. The reason for the receptacle is you have someone come into your house to do work. But they need a 20 amp receptacle for there tool. And you have a 20 amp receptacle on a 15 amp circuit well they are going to look at the 20 amp receptacle and say well there is 20 amps I will plug into that. You dont want them to mess up anything. Its basicly saying you have more power there than you really do.
Thanks! I replaced the switch and a power outlet without starting a fire or electrocuting myself, which for me is a big accomplishment since I am a home improvement idiot.
Thanks again for the help.
PS. for the 20 amp receptical I put in it my laundry room, which had the outlets on a 20 amp circuit.
Good information from both on this topic
Thanks for the info & code reference to look up
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
