-   -   Can I use a 20amp outlet receptical on a 15amp circuit? (http://www.diychatroom.com/f18/can-i-use-20amp-outlet-receptical-15amp-circuit-36254/)
abefroman 01-18-2009 01:12 PM
I have a power strip I need to configure and it has a t plug on it like this one:
http://cache.smarthome.com/images/4541w.jpg
(the power strip itself wont be using more than 1 amp, as I will have nothing plugged into it.)
I can I replace my 15amp receptical with a 20amp one, or is that generally a no no?
chris75 01-18-2009 01:16 PM
Can you? sure, but its a code violation.
abefroman 01-18-2009 01:17 PM
Thanks, I wont then.
Would a 15amp outlet work for a 20amp circuit? Or are they suppose to exactly match according to code?
theatretch85 01-18-2009 01:18 PM
Why not just replace the end on the power strip? Or better yet buy a new power strip that doesn't require a 20 amp plug on it.
abefroman 01-18-2009 01:24 PM
Because I have to set the IP address, then bring it somewhere else and plug it in as fast as possible.
dSilanskas 01-18-2009 01:32 PM
You can't put a 20 amp receptacle on a 15 amp circuit but you can put a 15 amp receptacle on a 20 amp circuit
abefroman 01-18-2009 01:34 PM
Thanks! Make sense now.
:jester:
abefroman 01-18-2009 01:36 PM
One more thing, same would go for a light switch right?
I can use a 15amp switch on a 20amp circuit, but shouldn't use a 20amp switch on a 15amp circuit, correct?
dSilanskas 01-18-2009 01:44 PM
I dont think that a light switch would matter. The reason for the receptacle is you have someone come into your house to do work. But they need a 20 amp receptacle for there tool. And you have a 20 amp receptacle on a 15 amp circuit well they are going to look at the 20 amp receptacle and say well there is 20 amps I will plug into that. You dont want them to mess up anything. Its basicly saying you have more power there than you really do.
Scuba_Dave 01-18-2009 01:54 PM
:jester:
A 15a receptacle has 20a pass thru - so its OK
abefroman 01-18-2009 02:43 PM
Thanks! I replaced the switch and a power outlet without starting a fire or electrocuting myself, which for me is a big accomplishment since I am a home improvement idiot. :)
Thanks again for the help.
PS. for the 20 amp receptical I put in it my laundry room, which had the outlets on a 20 amp circuit.
Jim Port 01-18-2009 04:38 PM
I always thought that Abe Froman was the sausage king of Chicago. :).
Beuller? Beuller?
abefroman 01-18-2009 04:46 PM
Beuller? Beuller?
Yep, I'm the sausage king but not the home improvment king :laughing:
nap 01-18-2009 06:19 PM
on a 15 amp circuit, you use a switch rated at least 15 amps. On a 20 amp circuit, you use a switch rated at least 20 amps. The intent is so you cannot overload the switch on whatever circuit it is on.
In other words, you can use a switch rated for 100 amps on a 15 amp circuit if you want but you cannot use a 15 amp rated switch on a 100 amp circuit.
chris75 01-18-2009 09:15 PM
Sorry nap, switches are rated by load... so I can install 15 amp switch on a 20 amp circuit. So as long as the load is not more than the switch is rated for.
Check out 404.14 (A)
