Can I Use A 20 Amp Outlet On 15 Amp Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 04:16 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Speedy Petey View Post
Sorry Andrew, this is just not so. A 15A circuit can ONLY have 15A receptacles on it.
See Table 210.21(B)(3)
This only applies to MORE than one receptacle.... I can legally install a 20 amp single round receptacle on a 15 amp branch circuit.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
kbsparky (11-12-2012), zappa (11-12-2012)
Old 11-23-2012, 04:14 PM   #17
Rewards Points: 77
I end up just running 12-2 everywhere and split it in two. I also ended up with unsed 14-2 at every receptacle. doh
nateo is offline   Reply With Quote
Old 11-23-2012, 06:49 PM   #18
Engineer
Rewards Points: 161
Originally Posted by joed View Post
[You can not put 15 amp receptacles on 20 amp circuits in Ontario either which I think is permitted in USA.]
Yes, you can do that in the US as long as receptacles is plural. Interesting that this is not the case in Canada.
diystephen is offline   Reply With Quote
Old 11-23-2012, 07:35 PM   #19
JuzRick's Avatar
Originally Posted by andrew79 View Post
To answer the original question, forgetting the jumble of code rules that you should and must follow already stated, you can have higher rated device on any type wire as long as the overcurrent protection is sized for the wire. So 20a receptacle on 14/2 with a 15a breaker is fine. It's useless as you only have 15a available though.
I agree. And it is covered in the NEC. I'm a residential electrician.. i just love this forum for more interesting pick up knowledge to take in the field. As the books states: It all just a practice. Meaning electrical is a learning trade, whether your a residential electrician.. or a master electrician! Just means you proceeded on to taking the additional test to obtaining the masters card(thats not towards u Andrew..just saying.)
JuzRick is offline   Reply With Quote
connect breaker to outlet circuit or junction box naty0629 Electrical 2 05-06-2012 06:46 PM
120-V outlets and 240-V outlet on same double-pole circuit? Daneel Electrical 24 04-03-2012 11:22 PM
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 02:00 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
