Can I Use #14 For 20 Amps - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 09:16 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Can I use #14 for 20 amps
The answer is NO!
More amperage, but just to give an idea of what could happen!
Stay safe people.
(and you probably thought I was actually asking that question )
Old 11-02-2011, 09:34 PM   #2
Code05's Avatar
Rewards Points: 1,104
Actually, the answer is: maybe. Got a motor or compressor?
Code05 is offline   Reply With Quote
Old 11-02-2011, 09:56 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Well, that video is a bit over dramatic. The guy is using a welder to run who knows how many amps through that cable, with a dead short at the end I suspect.
Not saying the answer to the title question is yes, but the outcome will be less dramatic. Similar under the right conditions, but less dramatic.
Old 11-02-2011, 10:53 PM   #4
Wire Chewer
Rewards Points: 46
Yeah definitely, but over a long period of time, perhaps. Probably more true if you ran 30 amps. I could see that as being a potential scenario, someone who decides to run a dryer on 14 or 12 for example.
Old 11-03-2011, 12:09 AM   #5
Maybe 20#
Carlos2sun is offline   Reply With Quote
Old 11-03-2011, 11:22 AM   #6
Rewards Points: 58
I ran a complete apartment on #12 THHN once for several weeks. The wire never even got warm, even with the range in operation. #14 will allow much more current to pass that you would actually ever let it allow. The NEC says a 15 amp breaker and #14 wire. That's all that matters.
dryer is 27 amps on 30 amp breaker whatrymes Electrical 2 03-30-2011 10:30 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
