Can I Splice Two Circuits Togehter Inside A Power Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 04:18 PM   #1
Question
Can I Splice two circuits togehter inside a Power Panel?
Hello,
I am working on my basement and I don't have any more room for breakers in my 30 fuse, 100A box.
I need to add 5 new circuits.
I have never tripped a breaker -- most of the existing lines are for one or two ceiling lights per room on the first and second floor.
Can I wire-nut some of the existing circuits together -- inside the power panel?
Thanks in Advance,
Tony
Noobie001 is offline   Reply With Quote
Old 01-23-2011, 08:53 PM   #2
Electrical Contractor
kbsparky's Avatar
Yes, this is possible. If the terminals on the breakers are rated for more than one conductor (Square D commonly has this rating), you can connect 2 wires directly to one breaker. If not, then you will have to use wirenuts, and a short pigtail to the breaker.
-KB
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
power to a sub panel BigHill Electrical 7 08-03-2010 01:36 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Pigtail inside panel box. Code allowed? KUIPORNG Electrical 7 08-22-2006 03:45 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
