Can I Screw A PVC Body Directly Into Wood? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 07:18 PM   #1
Can I screw a PVC body directly into wood?
Carlon's PVC j-boxes have mounting holes, but the LB bodies do not. Can I drill a hole into the body amd secure it to the adjacent sub-floor (I'm attaching from below)?
I think it's important to do this because the body will be the last piece, and subsequently the supporting piece, for the roughly 15-foot vertical section running from the basement (where the piece in question will be) to the attic.
The LB body (1-1/2") will be right next to a 6x6x4 box, which, if I don't screw in the LB body, will be the last screwed-in piece before the vertical run.
Ultimately, I want to know if it's code to put a metal screw in the body.
Thanks for your time.
Chris
Last edited by iceclimber2001; 08-21-2011 at 07:19 PM. Reason: Additional information.
iceclimber2001 is offline   Reply With Quote
Old 08-21-2011, 07:38 PM   #2
Missouri Bound's Avatar
For what it's worth....I have.
Old 08-21-2011, 07:39 PM   #3
Code05's Avatar
Rewards Points: 1,104
This is a kinda grey area of the code.
A pipe strap before the LB and one on the pipe up in the attic would be sufficient.
I am assuming the pipe is fished in the wall. Right?
Code05 is offline   Reply With Quote
Old 08-21-2011, 08:44 PM   #4
Yes, it is fished through the wall. I found a chase of sorts. There are virtually no opportunities to strap it to anything until the attic, which I haven't even broken into yet (although it's just the ceiling of a closet that's left to get through). I'll probably try to get a block of a 2x4, or whatever thickness needed, to attach that to a joist in the attic.
Or maybe It'll perfectly align with an attic joist... and I'll win Powerball this week.
Old 08-21-2011, 10:24 PM   #5
Idiot Emeritus
Rewards Points: 1,492
Me too.
It probably violates the UL listing, but I think that'd be awfully nit-picky.
micromind is offline   Reply With Quote
Old 08-22-2011, 07:26 AM   #6
I ask the impossible!
Rewards Points: 660
http://www.iaei.org/magazine/2006/01...-with-the-nec/
Conduit bodies are permitted to be supported by rigid and intermediate metal conduit, EMT, and rigid nonmetallic conduit, as appropriate, in accordance with the exceptions in NEC 314.23 (E) and (F).
It doesn't say you can't screw the conduit body into wood, but it says it must be supported by conduit that is supported according to code.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 08-22-2011, 02:47 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I screw through the back of PVC LB's all the time and am not ashamed to admit it.
IMO a screw through PVC is self-sealing, and it assures the LB stays straight and clean looking.
That said, I think it is a technical violation as well.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (08-22-2011), frenchelectrican (08-23-2011)
Old 08-22-2011, 03:40 PM   #8
Code05's Avatar
Me too. Similar to drilling an outside one for drainage, grey area.
Old 08-22-2011, 08:14 PM   #9
I found something in a 2011 guide that made it sound like it wasn't cool (non-code). I think I can secure one end using a 1-1/2 or 2" strap (can't remember which I bought after sizing it up). The glue and securing methods in the attic will have to suffice. I'm not worried that it will fail or cause any stress on the system whatsoever, if I pay attention to what I'm doing. "Above code" is my philosophy. Thank you, Mr. Cauldwell.
Old 08-23-2011, 12:23 AM   #10
" Euro " electrician
frenchelectrican's Avatar
I have done the same thing in both Américiane and European verison of LB fitting I know c'est a techanal voliation however some situation you have no choice but do it and my inspector did not say too much on that part.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Code05 (08-23-2011)
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 12:17 PM
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 09:05 PM
Timberlok or lag bolts on PT wood posts? spaceman spif Carpentry 6 09-17-2010 11:48 AM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
