Can I Safely Wire This Motion-sensor Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 04:21 PM   #1
Can I safely wire this motion-sensor light?
I have track lighting in my walk-in closet and it is wired to an inconveniently-located switch outside the closet. I am wondering if I can connect a motion-activated switch right here at the connection box for the track light (near the ceiling).
This is the type of switch I will use: http://www.amazon.com/Cooper-Wiring-...ch+fluorescent (the track lights are not incandescent). I would encase it in an external wall box so it looked neat.
Attached is a picture of how the track lighting is currently wired. It looks like I have hot, neutral and ground wires.
Questions: Can I do this safely? Would I need to connect the wall box to the track connection box pictured here (for grounding purposes)?
KellyAL is offline   Reply With Quote
Old 01-14-2013, 05:09 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,822
You could, but it cannot be a switch leg. That means that power would have to enter at the switch. If you have a switch leg, you would need a neutral. That means 3 wires plus the ground.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 01-15-2013, 11:40 PM   #3
Thanks, gregzoll! I had to do some research on switch legs before I could respond. A few questions:
1) What you're saying is that with the current configuration of wires, I could not do what I suggested without running an additional wire to where the new switch will be?
2) I will not need the existing switch (outside the closet) after I install the motion sensor switch (inside the closet). Does this change anything? If I deactivated the old switch, could the only switch leg would be to the new switch? How would I do that, and again, would that involve pulling more wire through the wall?
Pulling additional wire behind the wall is beyond my ability. It just seems like I should be able to capitalize on the shoddy outside-the-wall hardwiring job that the previous owner did here...
Tags
motion sensor , motion-activating
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 02:05 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
