Can I Run THWN Inside An Aluminum Post? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 04:27 PM   #1
Can I run THWN inside an aluminum post?
I'd like to run THWN inside aluminum posts on my screen porch and put an outlet on the outside of the post. Is there anything that would prevent me from doing this as far as code? It seems like it isn't much different than doing conduit or wire molding (other than the fact that is load-bearing)
phareous is offline   Reply With Quote
Old 07-09-2013, 04:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Nope, not an approved wiring method.
Old 07-09-2013, 04:54 PM   #3
Ok how about if I do UF inside the column?
Old 07-09-2013, 06:29 PM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Yes that would be fine...UF
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 07-09-2013, 07:07 PM   #5
Rewards Points: 1,192
That's how we wire roadway lights.
bobelectric is offline   Reply With Quote
Old 07-09-2013, 07:52 PM   #6
k_buz's Avatar
Apples and oranges
Old 07-10-2013, 03:49 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,892
The light pole is part of the UL listed fixture assembly, so it's intended to be used that way. The posts on this patio are not. UF cable is the easiest code-compliant solution I think.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
MTN REMODEL LLC (07-15-2013)
Old 07-10-2013, 08:23 PM   #8
kbsparky's Avatar
Some aluminum porch manufacturers offer UL listed wireway channels as part of their support posts.
IF yours is one such listed post, then you can install THHN/THWN wiring without any further cabling or raceways.
-KB
Old 07-10-2013, 11:54 PM   #9
So I need some advice. I was going to use metal receptacle boxes that have 1/2" threaded hole in the back. I can't find anything to secure the wire in the box. I need to have two 12-2 UF in there. The UF connector I found would only support one cable. I found a pvc male adapter that would fit but the outside is too big to go into the hole I drilled and it wouldn't really secure the cable anyway (only keep it from getting snagged on the drilled hole). I tried a plastic nm ring but it wouldn't fit. I think maybe I could use a threaded clamp of some sort if I could find one. Another issue with the boxes I have is they have metal ribs on the back (I assume to dig into wood)..but I may need to grind that off to sit flush with the pole.
What kind of boxes and clamps would you use if you did this?
Old 07-11-2013, 12:16 AM   #10
I'm thinking maybe I could use rubber grommets in the hole I cut? I would still need to clamp the wire in the box per code right?
Old 07-11-2013, 07:24 AM   #11
JW
mm11's Avatar
Rewards Points: 596
Use a NM connector, listed for 2 cables. You'll probably need to ream the hole already cut to accept the connector, but the box will definitely cover the larger hole.
mm11 is offline   Reply With Quote
Old 07-11-2013, 12:14 PM   #12
Rewards Points: 80
Personally, I would use a chase nipple instead of a connector. Not exactly compliant, but what i would do none the less.
J. V. is online now   Reply With Quote
Old 07-14-2013, 12:57 AM   #13
So what I did was get the plastic bushing designed for metal studs. I put those in the holes in the posts to protect the wire. Then I screwed the boxes to the posts and put the nm connector on there backwards (with it coming into the box) and used needlenose pliars to screw down the connector screws. I could not do it the other way as the connector would not go through the post hole without making the holes twice as big. Inspector comes Monday...I guess I'll soon know if it was ok or not
Old 07-14-2013, 02:07 AM   #14
That's definitely not a code compliant way of using the connectors, but an inspector might pass it. A snap-in plastic connector would probably fit the right way.
Old 07-14-2013, 08:37 AM   #15
I can't find a plastic snap in connector that would fIt a 1/2 threaded hole
Replace post between roof and concrete patio. clintonb Building & Construction 4 05-27-2013 07:10 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 10:56 AM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 09:04 PM
