#1 |
Can I run a small (500 watt) 240 V space heater at 120V?
Stupid question but will it work and is there any safety reason not to do this? Will it only put out half the wattage, or will it draw 2X the current, or both or neither? I know the wire to it is a 12/2 home run, and not very long, so I don't think 500 watts is the concern.
This is electric baseboard BTW. EDIT... Just read that in fact it will put out 1/4 of the power... does that sound right? Not going to heat up even a little bathroom I'm sure!!! Last edited by pcampbell; 01-08-2009 at 06:16 PM. |
#2 |
Floor Sweeper
Yah, sounds right.
#3 |
Why run it at 120? 12/2 will give you 240.
#4 |
I only have one 1" spot left. No worries, thanks...
#5 |
Can I run a small (500 watt) 240 V space heater at 120V? |
#6 |
Or, combine circuits that aren't being used efficiently.
Example: My basement (finished) has two fluorescent lights on a 15A breaker. I can add lots more to that branch.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Idiot Emeritus
A 500 watt heater designed for 240 volts and operated on 120 will produce 125 watts. The current will be 1.04 amps.
Provided it's a heating element only (no fan), it will not be damaged, and not the slightest bit unsafe. Rob |
| Display Modes | |
| Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
| How should I circulate air in small space? | Imgood | HVAC | 5 | 07-15-2008 07:51 PM |
| small electric heater recommendation | bdog1234 | Electrical | 9 | 02-24-2008 03:12 PM |
| How to Space Water Heater Flue Vent from Outside Wall? | austinbirdman | Plumbing | 1 | 03-12-2007 11:28 AM |
| Space Heater And K-1 Kerosene | bobo | General Discussion | 7 | 10-25-2006 11:38 PM |
