Old 08-25-2010, 03:30 PM   #1
Can I run romex across garage wall?
I need to extend a hot 12-2 line in my garage. Right now it terminates on the right side wall. The wall in the past was the exterior of the house and is clapboard siging over 1" rough cut sheathing. The other side of the wall is finnished sheetrock.
I want to extend the wire about 6 feet. Can I put a junction box there and run romax in a 6 foot horizonal run on top of the clapboard to the other junction box I need it at? If not, can I use a armor coated cable or conduit maybe?
Snaking the wire in the wall looks very hard and I want it to be my last resort.
Thank you!
heyd is offline   Reply With Quote
Old 08-25-2010, 03:32 PM   #2
Jack of all - master none
hyunelan2's Avatar
AFAIK, you cannot run romex outside of a wall unless it is armored. The wires need to be protected by something - usually the wall.
hyunelan2 is offline   Reply With Quote
Old 08-25-2010, 10:21 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Normally in Garage if you run the romex cable horzontally it have to be protected by either use the studs like run up and go over the trusses then back down or in MC cable { this one of few items I will allow it } otherwise conduit if surface mounted.
But IIRC once over 7 or 8 foot level then there is no restriction { I have to check this part to make sure }
Merci.
Marc
Wall between attached garage & interior - waterproofing cham44 Building & Construction 8 08-21-2010 12:27 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Partition wall in garage pomelo Building & Construction 7 11-23-2009 10:46 PM
garage mudroom wall composition jutah Building & Construction 3 01-06-2009 06:33 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
