Can I Run Low Voltage Power In Same Conduit As Security System Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 10:10 AM   #1
Rewards Points: 16
Can I run low voltage power in same conduit as security system wire?
I searched and it seems that I can, but wanted to pose my specific situation to the experts:
I am putting a keypad/video camera entry system in front of our house. It requires a 18/4 shielded stranded wire. It also requires 12v DC power. This unit is going on a gate i'm building (along with the wall) about 10' away from the house and about 30' away from where the monitor/intercom is going in the house.
I have 2 gang boxes (one single [where the 18/4 security cable is being run to and then into the house] and one double[where the 110 is coming into from the house and then going to the driveway gate motor]) at the edge of the house that I just put there, so about 10' away from the gate, and am running 3/4" plastic conduit to the keypad. I figure it's overkill but it's only pennies more than 1/2" and i see no reason not to have it.
Anyway, here is my question: without going into any more detail, I can hardwire the transformer in the double box with the 110, run the 12v DC from there into the next box with the security and then run both together in the 3/4" conduit to the location on the gate.
I was planning on using the 18/4 shielded stranded cable for the keypad's video and intercom and 16/2 shielded stranded for the keypad power.
does anyone have thoughts if this should be ok, is going to be a problem or have alternate suggestions??? thanks so much!
jfryjfry is offline   Reply With Quote
Old 10-20-2012, 11:36 AM   #2
Missouri Bound's Avatar
It's unlikely. I believe you could if the insulation of the low voltage wire allowed it but I do not think the insulation of your low voltage wire would. I personally would find another way to run it. Someone with more expertise in this area will no doubt chime in.
Do you want it your way or the right way?
Old 10-20-2012, 11:41 AM   #3
Rewards Points: 6,652
Done all of the time with video security systems.
Old 10-20-2012, 11:44 AM   #4
Rewards Points: 16
awesome. i thought it would be okay but good to hear it is common practice.
anything I should make sure I do to help guarantee no problem?
is shielded wire the best bet for both the power and the comm wire? should i wrap either wire in something else to help isolate them? thanks again!
Old 10-20-2012, 11:46 AM   #5
See NEC 300.3 (c). As long as the insulation of the wire is rated at the highest voltage in the conduit it is allowed.
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
14/3 Power Cord in conduit NotSoElectric Electrical 10 09-05-2011 09:40 AM
safety near house power line conduit ChrisJJ Painting 7 08-13-2010 09:44 AM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
