Can I run electrical wire BEHIND my basement walls?
Originally Posted by Beepster
Just drill the holes and run through the studs already. As previously mentioned, all the wiring has to be secured every so many feet. It will probably take longer to do that than the job you are trying to avoid in the first place.
Why the gap betweeen the studs and walls? Uneven walls?
B
The gap has to be there to allow the outside wall to breathe. Without it, and insulation pushed up, you get mold and mildew.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
