Can I Run 2 Wires In Each Stack-it Space Like This? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 09:05 PM   #1
Rewards Points: 262
Can I run 2 wires in each Stack-it space like this?
Is this acceptable, or is it one wire per space (which seems really loose!)?
tpagel is offline   Reply With Quote
Old 06-27-2011, 09:15 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What does the bag state?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-27-2011, 09:18 PM   #3
Rewards Points: 262
Unknown. I was given these by a friend, to make my renovation wiring go easier. I have never used them before. Wanted to double check before my first inspection next week. The wires are far more secure with 2 in each space. If there is no easy answer, I will look for the manufacturer online, I guess.
Old 06-27-2011, 09:28 PM   #4
Rewards Points: 6,652
What are you powering with the mix of #12 & #14 in there? Looks like you might also be maxing out the box fill from just the little bit you posted.
Old 06-27-2011, 09:34 PM   #5
Lic Elect/Inspector/CPO
This type of stacker allows two wires in each slot, but they have to be side by side, not on top of each other.
NJMarine is offline   Reply With Quote
Old 06-27-2011, 09:36 PM   #6
Rewards Points: 262
I have one 14/2 homerun coming from the sub panel into the box. It powers 1 switch which controls 2 recessed downlights and powers another switch which controls two runs of undercabinet task lighting (2 switch legs out to each side of the room, since the lights are not continuous), and a third wire goes across the room to provide power to a switch there which controls 3 accent pendants lights. Additionally, the 12/2 wire comes in from an adjacent outlet (not the code required dedicated counter outlets), to a switch which will control an outlet that a toekick heater fan will plug into. So basically, 3 switches with an extra feed out to another switch. It's a triple switch box. Do I need to go bigger for more capacity?
Old 06-27-2011, 09:37 PM   #7
Rewards Points: 262
NJ Marine - Thanks very much!
Old 06-27-2011, 09:38 PM   #8
electures's Avatar
Here is the website link. Couldn't find anything specific but you can request info.
Old 06-27-2011, 09:48 PM   #9
Rewards Points: 262
thanks electures. I appreciate your help
Old 06-27-2011, 09:50 PM   #10
Electrician
SD515's Avatar
Rewards Points: 504
Is that a 42 cu in box? Should be stamped inside the back. You're going to have 3 switches? 2 hooked up to 14ga and 1 hooked to 12ga?
Kyle
Old 06-27-2011, 09:53 PM   #11
Rewards Points: 262
SD515.... 52 cu in box. Also said 26-14, 23-12, 20-10. And yes, two 14 ga switches and one 12 ga switch
Old 06-27-2011, 09:57 PM   #12
Rewards Points: 262
I am also still in the dark as to this situation. I didn't understand if this would work somehow or not, so I posted a photo of the box. More comments on this would also be most appreciated.
OK. 1 extra wire. Now what?
Old 06-27-2011, 10:00 PM   #13
Electrician
SD515's Avatar
Rewards Points: 504
You're good on capacity then.
Kyle
Old 06-27-2011, 10:18 PM   #14
Licensed electrician
Rewards Points: 1,266
SD515 and I agree that the circuit should not be extended due to being 8ngrounded.
SD515 (06-27-2011)
Old 06-27-2011, 11:56 PM   #15
Rewards Points: 1,016
Product Documentation
http://multimedia.3m.com/mws/mediawe...&fn=SIFSDS.PDF
____________
Vince
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 07:32 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
