Can I Put These On One 20a Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2013, 12:12 PM   #1
Rewards Points: 874
Can i put these on one 20a breaker
Want two put two of these baseboards and 5 outlets that will just have a lamp in one and tv, cable box and DVD player in another ??
http://m.lowes.com/product?langId=-1...lue=4294765322
Mstrlucky74 is offline   Reply With Quote
Old 12-17-2013, 12:28 PM   #2
Master Electrician
Rewards Points: 3,698
No. The heaters are 1000 watts @240 volts. Normal convenience receps are 120 volts.
brric is online now   Reply With Quote
Old 12-17-2013, 12:34 PM   #3
Rewards Points: 874
Ok thanks but I only need to pull two hots and a ground to a 2p 20a breaker for the heaters and it can #12's?? Thanks
Old 12-17-2013, 01:17 PM   #4
Master Electrician
Both heaters could be on one 240 circuit using 12-2 w/ground.
They could actually be on a 15 amp 240 volt circuit using 14-2 w/ground.
The Following User Says Thank You to brric For This Useful Post:
Mstrlucky74 (12-17-2013)
Old 12-17-2013, 01:36 PM   #5
Rewards Points: 874
Why are there 2 different wattages and amps listed for this baseboard?thanks
Old 12-17-2013, 01:51 PM   #6
Master Electrician
Low and high. Those are not the same heaters in your previous link.
Old 12-17-2013, 02:45 PM   #7
Rewards Points: 874
I know I was just Home Depot and was curious thanks
Old 12-17-2013, 03:18 PM   #8
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 442
Just an FYI: watts divided by volts = amps.
2 x 1000 watts heaters /240 volts = 8.33 amps total for two.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Old 12-17-2013, 06:06 PM   #9
Rewards Points: 874
Originally Posted by 123pugsy
Just an FYI: watts divided by volts = amps. 2 x 1000 watts heaters /240 volts = 8.33 amps total for two.
The baseboard will not have a t-sat so I'm gonna have a separate one. So I run 2 hots and a ground from panel to t-stat than from the t-stat to the baseboards? Thanks
Old 12-17-2013, 06:50 PM   #10
Licensed electrician
Rewards Points: 1,052
That would be correct for a wall mount t-stat.
Old 12-17-2013, 07:22 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,098
Could it be two elements each one 750w @ 120v ?
You select one for low or both for high ?
It also would allow for 120v or 240v.
Just a thought ?
dmxtothemax is offline   Reply With Quote
Old 12-17-2013, 08:10 PM   #12
Master Electrician
Just a thought ?
The data sheet indicates 120volts with a dial for off-low-high. It is a cord and plug unit.
Fahrenheat LFP 6152E.
New Breaker installed- Main Breaker trips novy31 Electrical 14 10-30-2013 09:08 AM
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
