Can I Put Electrical Tape Around The This Bare Copper? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 08:03 AM   #1
Can I put electrical tape around the this bare copper?
Hello, it's the idiot electrician again.
Can I wrap electrical tape around this bare copper?
I can't cut it: there's not enough wire left, and I can't pull it out: it was bent when I pushed it in; in fact, the exposed wire is just insulation I pulled back from trying to pull the wire back out.
If I have to cut it, can I just a wire with electrical tape, or is that just a recipe for disaster?
Thank you for your time.
W_Mitty is offline   Reply With Quote
Old 05-28-2011, 08:06 AM   #2
Electrical Contractor
kbsparky's Avatar
There should be a small slot adjacent to the hole where the wire is inserted. Press a small screwdriver into that slot, and that should release the stronghold on your wire.
Once you get the wire removed, bend a hook in it, and use the terminal screws instead.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
W_Mitty (05-28-2011)
Old 05-28-2011, 08:09 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
But use the screw terminals on a new receptacle. That is an old junk receptacle that is likely near the end of it's usable life anyway.
And you can cut it. There is plenty of wire to make up new. Just cut it right at the back of the device. You'll only lose about 1/2".
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 05-28-2011, 09:52 AM   #4
Here's the finished product; everything good and in order?
Thanks again for your time.
Can I put electrical tape around the this bare copper?-100_3506.jpg   Can I put electrical tape around the this bare copper?-100_3507.jpg
The Following User Says Thank You to W_Mitty For This Useful Post:
gregzoll (05-28-2011)
Old 05-28-2011, 10:24 AM   #5
jbfan's Avatar
Rewards Points: 138
The black wire is wrapped in the wrong direction.
The Following User Says Thank You to jbfan For This Useful Post:
SD515 (05-28-2011)
Old 05-28-2011, 10:28 AM   #6
joed's Avatar
Rewards Points: 11,552
Noticed the same thing.
The wire should be wrapped so that when the screw is tightened the hook closes not opens.
Also screw the unused screws in before installing into the box.
Old 05-28-2011, 10:28 AM   #7
Rewards Points: 460
Looks good/safe. An electrician would wind the wire in the opposite direction so that when screw is tightened, it will not tend to back off at last tightening. As long as tight, it's fine.
diyorpay is offline   Reply With Quote
Old 05-28-2011, 10:30 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Black wire is looping the screw in the wrong direction looks like.
Remember? That was mentioned in your other identical thread. This is why one thread per topic would be best.
XXX
Old 05-28-2011, 10:37 AM   #9
Yeah, I absentmindedly thought the same direction as in "both should start on the top and curl down." Notice I did do the white correctly - this time.
Sorry, I started a new thread since I thought the topic was separate: the first topic concerned excess copper from a screw, while the second concerned excess copper from the back of the plug; then I continued in the second thread as, yeah, I thought three threads might be a bit much.
Thank you everyone for the help; I don't want to die in a fire.
Old 05-28-2011, 10:37 AM   #10
Does the wire need to be a closed loop around the screw? I've found that nearly impossible to do.
Old 05-28-2011, 10:39 AM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Hey, is that black wire looped in the wrong direction?
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-28-2011, 10:40 AM   #12
jbfan's Avatar
Rewards Points: 138
No! Just like the white wire will do.
Old 05-28-2011, 10:46 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes you did !!! Go get a cookie for yourself and your friend !!!
XXX
Old 05-28-2011, 10:49 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is the wire short enough on this electrical socket?
XXX
Old 05-28-2011, 01:53 PM   #15
Licensed electrician
Rewards Points: 1,020
The insulation on the white looks like it is under the screw head. Only bare copper under the screw head.
Also if that is #12 it cannot be used in the backstabs. Only #14 in the backstabs.
Tags
electrical tape
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 05:21 PM
Using electrical tape Fazil Electrical 11 02-05-2011 12:34 AM
Liquid Electrical Tape? WaldenL Electrical 10 11-18-2010 10:19 AM
Electrical solder on copper pipes? mosh Plumbing 1 10-30-2009 10:36 PM
Bare Ground Wires MrBill_DIY Electrical 4 10-05-2008 08:05 PM
