#1 |
Can I put #6 on a 30A breaker?
I'm having trouble finding a 50A breaker for my sub-panel, so for the time being I'm planning to use a 30A that's no longer being used.
How do I know if the #6 wire is allowed under the 30A breaker screws? Is it listed on there or something? Or is it just ok if it fits? If it's not ok, I assume a pigtail to a smaller wire size would have to be outside the main panel, in another junction box, right? |
#2 |
So Cal Electrician
#6 is fine, going bigger on wire is not a bad thing, however going smaller is.
Well....Butter my butt and call me a biscuit! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Licensed Electrical Cont.
That is only if the breaker will accept it.
It will say somewhere on the breaker what the wire range is.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#4 |
Thanks Speedy. That's what I was wondering.
If it won't accept #6 do I have to pigtail down to something that fits OUTSIDE the panel (in another junction box)? |
#5 |
What's the point of a 30A breaker that only accepts 10-14 AWG wire???
anything smaller than 10 would be a violation, and any long runs or anything might use 8 at least. Seems silly. Anyways, I'm off to get some #10 for pigtails. Is it wrong to put romex in a conduit. It's somewhat temporary, if that matters. |
#6 |
So Cal Electrician
don't put romex in there permanetly, temp should be ok.
#7 |
Licensed Pro
There are instances where wire smaller than #10 will use a 30A breaker (AC circuits for instance).
Whether or not #6 will fit yours depends on the design of the breaker. As Petey said, check the breaker. If you have room in the panel, make the pigtail there. That way you won't have to run more wire when you "find" the correct size breaker. |
#8 |
It was cheaper to get THWN, so I've got it connected to the #6 at a junction box just downstream of the panel. Now if I can manage to buy an SDT250 from the guy on Ebay who just bought a lot of NINE of them!
#9 |
So Cal Electrician
Now those are hard breakers to find, unless you have a cb rebuilding shop right down the street
#10 |
There are a lot of 15s and 20s on Ebay, but the high amperage ones are tricky to find.
#11 |
What am I missing here? I can pick up a 50 amp breaker at any ma & pop ACE hardware store. Or I can go to town and buy one at HD. Is this a special species 50 amp your're talking about?
#12 |
So Cal Electrician
very special 50 amp, not made anymore...different connection to bussing
#13 |
So Cal Electrician
I think this is the breaker he is looking for...it's a trilliant type square d double pole 50 amp
#14 |
Well, then I'd say you're lucky to have a handy 30A available. Good luck in you're seach. I'd be interested in the outcome.
#15 |
Everyone keep your eyes out for one of those.
![]() I'll pay a finders fee! |
| Display Modes | |
| Circuit breaker panel - Advice needed | justtired | Electrical | 15 | 12-13-2007 06:55 AM |
| Outdoor breaker panel questions | lhoney2 | Electrical | 12 | 07-19-2007 06:44 PM |
| Breaker Buzz | SkipI | Electrical | 2 | 07-13-2007 08:48 PM |
| Holy smoking commander breaker | drogosandybanks | Electrical | 13 | 01-10-2007 03:34 PM |
| Breaker keeps being thrown (solution?) | JH7800 | Electrical | 4 | 06-28-2006 04:55 PM |
