Can I Put A 3 Wire Romex Into A 2 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2013, 05:16 PM   #1
Smile
Can I put a 3 wire romex into a 2 wire
Hello,
I have a bathroom exhaust fan that has only 2 wire romex out of the ceiling. I want to install a fan with the heat and light and it requires a 3 wire connection. Can I put a 3 wire on the 2 wire? The bathroom is on the other side of the house so I am not sure where to run this to the fuse panel. Any help is much appreciated. Thank you
pugmom is offline   Reply With Quote
Old 08-16-2013, 05:53 PM   #2
Resi EC
Rewards Points: 252
Is this a heat lamp, or resistance heating?
If it's resistance heating it will require a 20 amp dedicated circuit.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
gregzoll (08-16-2013)
Old 08-16-2013, 06:01 PM   #3
Rewards Points: 6,652
How hard would it be for you to pull a run of 12/3 Romex or AC up to where the unit will be in the ceiling, and where the switches are, along with 12/2 from the panel to the switches, or to the fixture, then use a "Switch" leg from the fixture to the switches?
Old 08-16-2013, 06:48 PM   #4
joed's Avatar
Rewards Points: 11,998
If the direction require two separate circuits for the unit then you must install it that way. Code requires all devices to be installed according to manufacturer directions.
Old 08-16-2013, 06:59 PM   #5
Licensed electrician
Rewards Points: 1,264
The junction box on the unit is very small. I would not try switch loops from the fan.
stickboy1375 (08-16-2013)
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
3 wire romex to electrical panel and GFI? dvarga Electrical 16 05-17-2012 10:32 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Can I use 10 guage Romex Wire to rewire my house? joshua_r_86055 Electrical 4 06-28-2011 08:15 PM
romex with thin grounding wire dogbone Electrical 16 01-10-2009 09:40 PM
