Can I Place Receptacle Under Island Countertop Overhang? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 10:15 PM   #1
Can I place receptacle under island countertop overhang?
Hello,
Is there any way for me to place the 1 required receptacle on my kitchen island under a 10" overhang?Because I don't want to cut into my stone.The counter top and 2 vertical end panels are stone,only the cooking side and opposite bench side has wooden panels.
Could I get away with putting the required outlet inside the cupboard as another option if not under overhang?
thanks,
iosif
iosif is offline   Reply With Quote
Old 05-31-2012, 10:28 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Does the counter top overhang on the sides as well as the back of the island? If not, then you could cut an outlet (GFI protected) into the back panel in one of the upper corners. I would suggest installing one in each corner, but it is not required.
You would not meet code if you install the outlet(s) more than 6" from the corners. Mounting the outlets inside the cabinets does not satisfy the requirement for an island outlet.
I will try to make up a quick picture to show you what I mean.
Old 05-31-2012, 10:28 PM   #3
Rewards Points: 12,868
http://ecmweb.com/nec/code_qa/code_qa_071307/
Old 05-31-2012, 10:36 PM   #4
k_buz's Avatar
Here is what I am talking about in pictures....
Old 06-01-2012, 06:54 AM   #5
Trying to Meet Code Requirement for receptacle at Kitchen Island.
Unfortunately it does hang over on the sides as well as the top.The stone counter top wraps around all the way to the ground.
How about if I mount a receptacle on the opposite side-on the panel between my range top and oven?(the range top is on the right and the oven on the left).
Would that meet the code requirement?
My entire aim is to avoid making holes in the stone.
Thank you,
iosif.
Old 06-01-2012, 08:04 AM   #6
k_buz's Avatar
How far does the counter overhang the lower cabinets on each side?
I know the counter overhangs 12" on the back of the cabinet.
Old 06-01-2012, 08:21 AM   #7
Can you build a 3x4 enclosure under the countertop to hold the receptacles?
puttster
puttster is offline   Reply With Quote
Old 06-01-2012, 09:09 AM   #8
It overhangs on the sides the same as the top.so in essence the counter top continues as it is on top over the sides to the ground.
I am tight for space on the front cooking side where the stone top comes flush to the panel. Maybe I could try something there?
Forgive my ignorance,but is there a small or single outlet GFI,where i could try squeeze it between the gas range top and the oven?
If i learn to post pics I'll send an example.
In the area I am located,we are not under code.However my builder won't release the house or give his guarantees unless it meets code,which I understand.
Thanks K_Buz for your help.
Old 06-01-2012, 09:14 AM   #9
Hello Puttster,
I'm not sure I fully understand what you mean,but I would very much like to understand.Perhaps that's the answer I'm looking for.
Could you please describe how this enclosure is built and where exactly it would be installed, so as to meet code requirements?
thanks,
iosif.
Old 06-01-2012, 09:23 AM   #10
Hello K_Buzz,
It is more or less like this.
My range top is on the left though and my oven on the right in the counter.
Thanks,
iosif.
Old 06-01-2012, 09:33 AM   #11
Sparky
Rewards Points: 510
you're almost certainly going to be required to cut the stone in some fashion
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
k_buz (06-01-2012)
Old 06-01-2012, 10:54 AM   #12
k_buz's Avatar
Is there a "lip" on the edge of the overhang?
Old 06-01-2012, 12:11 PM   #13
1/2"lip on working side.
Thanks,
iosif
Old 06-01-2012, 12:58 PM   #14
k_buz's Avatar
You might be able to run a pipe sleeve out from the cabinet and hook or up to some Plugmold on the under side of the overhang. It would have to be within 6" of the edge of the countertop. The hard part would mounting it to the stone. Maybe some double-sided tape.
Old 06-01-2012, 03:14 PM   #15
K_Buzz,
That I think will be the best solution!
I will mount it to the underside of the stone with something like liquid nails or epoxy( not more than 6" from the overhang edge).
Then I'll run sleeved romex along the stone through my cabinet.
Sir you have been most helpful, and I am very appreciative of that !
I'll try send a picture when I'm done.
Thanks again,
iosif.
Electrical power disappeared from switch to receptacle craighank Electrical 3 02-19-2012 02:06 PM
How to seal around receptacle box going through tile? darlingm Electrical 2 01-23-2012 10:34 PM
Replacing old receptacle (PICS) picflight Electrical 14 10-28-2011 08:05 AM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 09:59 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
