Can I Mix Conduit And Romex - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 10:25 AM   #31
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Based on the info given and my research, the wiring is considered class 1 and not class 2.
If it was class 2, then legally you could not run them inside the same conduit.
Old 02-07-2012, 10:31 AM   #32
Julius793's Avatar
what info where you given that's makes you come to that conclusion?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-07-2012, 10:33 AM   #33
jbfan's Avatar
Rewards Points: 420
Based on the info given by the op, my research and other electricians I have talked to.
and you don't have to be so condescending about it in your pm's either!
Old 02-07-2012, 10:46 AM   #34
Julius793's Avatar
My research has been that What will ultimately be the deciding factor is the power source. And as I pmed you you can take a look at my post on et.
Tags
alarm , septic , septic control
Joining romex and conduit Restyle Electrical 2 11-08-2011 03:01 PM
loose Romex entering EMT conduit inside ceiling amakarevic Electrical 6 11-02-2011 09:32 PM
loose Romex into plastic conduit box amakarevic Electrical 4 06-30-2011 09:27 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
