Can I Make This Electrical Setup Work? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 11:02 AM   #1
gte
Can I make this electrical setup work?
Hello,
I made a mistake and forgot to put a feed to switch 1, before I drywalled. I can always run new wiring, but I'm hoping I can avoid that if possible because the drywall is already up.
My question is, is it possible to still use the 3 conductor wire to feed power to switch 1 and then still have the 3 way functionality between switch 1 and switch 2, before feeding power to the 2 conductor wire that goes from switch 2 to the light fixture?
gte is offline   Reply With Quote
Old 11-08-2012, 11:22 AM   #2
Licensed electrician
Rewards Points: 1,264
Yes, you will wire SW1 as a dead end 3w. At SW2 box splice the incoming hot to the W from the cable going to SW1. Re-identify this as a hot with black tape or magic marker. Place this on the Common terminal at SW1. Black and red are the travelers at SW1 and SW2. The black going to the fixture connects to the Common on SW2. The white from the fixture splices to the incoming white.
The above procedure is not in compliance with the 2011 NEC requirement for a neutral at the switch locations.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
gte (11-08-2012), sublime2 (11-08-2012)
Old 11-08-2012, 11:26 AM   #3
gte
Thank you Jim!
I'll try that tonight
Old 11-08-2012, 11:55 AM   #4
joed's Avatar
Rewards Points: 11,998
Here is a drawing of what you have.
The Following User Says Thank You to joed For This Useful Post:
gte (11-08-2012)
Old 11-08-2012, 12:23 PM   #5
gte
Thank you so much! I was just trying to draw it up myself
Old 11-08-2012, 01:19 PM   #6
The diagram posted does not agree with the instructions I posted.
Old 11-08-2012, 02:14 PM   #7
gte
Hi Jim,
This is the diagram I was working on, does this reflect the instructions you posted properly?
Old 11-08-2012, 02:18 PM   #8
You got it. Nice diagram.
Old 11-08-2012, 04:34 PM   #9
gte
Thanks, good instructions make a good diagram
I have my head completely wrapped around it now, the switches are just SPDT relays .
You feed the input of the first SPDT relay (switch 1) with power and then you connect both outputs of the first SPDT relay to the outputs of the second SPDT relay (switch 2) and then connection the input of the second SPDT relay (which is actually technically an output) to the light fixture. You also wire nut the neutral from the fixture right to the wire that goes to the panel inside of the gang box, bypassing all switches.
Old 11-08-2012, 09:38 PM   #10
joed's Avatar
I did not read your instructions. It does agree with the poster's original line drawing with power and light going to one of the three way switches.
There are no relays involved. They are both switches.
Old 11-13-2012, 10:20 AM   #11
gte
Hello,
I was making an analogy with the relay comment, not a definement.
Anyway, this worked well and is functioning as of Friday. Thank you Jim.
Old 11-13-2012, 11:38 AM   #12
You are welcome.
Old 11-13-2012, 12:30 PM   #13
langless28's Avatar
Rewards Points: 152
as per the 2011 NEC, doesn't a neutral have to be at every switch location?
langless28 is offline   Reply With Quote
Old 11-13-2012, 12:35 PM   #14
gte
It seems as if no one is reading the whole thread
Old 11-13-2012, 12:45 PM   #15
langless28's Avatar
Rewards Points: 152
yeah i missed the neutral part, because of the ads on this site being in some posts, my eyes tend to skip stuff towards the end.
homeowner electrical work spazpatnaude Electrical 3 01-24-2012 04:05 PM
Torque Letter? bigmacfann Electrical 14 08-11-2010 11:40 AM
ideas on how to make a fold down work table kimber Carpentry 2 10-08-2009 12:56 PM
Electrical codes from 1970's -- Old work frustrations... PirateKatz Electrical 3 03-18-2009 07:35 PM
bifold alternative or how to make bi fold work Janie Carpentry 8 03-16-2009 06:45 PM
