Old 07-05-2011, 04:20 PM   #1
Can i install a hunter wireless remote in a three way switch configuration?
Can i install a hunter wireless remote in a three way swithch configuration and use two wireless remotes programmed to the same code>
werova is offline   Reply With Quote
Old 07-05-2011, 04:25 PM   #2
Master Electrician
Yes you should be able to do that, assuming you are using the three ways for on/off power to the fan and you are installing a receiver at the fan. No need for two remotes unless that's what you want.
brric is offline   Reply With Quote
Old 07-05-2011, 04:25 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
What does the manufacturer directions state about using their equipment in that configuration?
Old 07-05-2011, 04:36 PM   #4
the three way defeats the remote.you need constant power to fan/lite.why do you guy's always want to screw with things?
oleguy74 is offline   Reply With Quote
Old 07-05-2011, 04:38 PM   #5
Master Electrician
So would a single pole switch. What is your point?
Old 07-05-2011, 04:55 PM   #6
gregzoll's Avatar
Actually not brcc.
Old 07-05-2011, 04:57 PM   #7
the point is with a three-way,every time you want to use fan/lite,you need to flip one of the three way switches to get power to fan/lite.and yes one single pole sw is eaiser.if you use the three-way idea,turn switches so fan/lite comes on,then buy those plastic screw on devices that prevent switches from operating.the if you want to work on fan/lite,remove the stop on one of the 3-way switches,turn power off,turn plastic locking device screwed to other plate screw so no one can turn power on.when done return locking device to stop power from being turned off so remote works.
Old 07-05-2011, 04:59 PM   #8
Originally Posted by gregzoll View Post
Actually not brcc.
if he uses only one sw,a single pole is fine.
Old 07-05-2011, 05:06 PM   #9
Master Electrician
Makes no sense at all. If the circuit is on the remotes will work.
Old 07-05-2011, 05:06 PM   #10
Master Electrician
Actually not brcc.
Why not? They work fine in my house.
The Following 2 Users Say Thank You to brric For This Useful Post:
SD515 (07-05-2011), secutanudu (07-11-2011)
Old 07-05-2011, 05:37 PM   #11
if someone truns off one of the three-way switches,no power to lite/fan.there for no workie..
Old 07-05-2011, 06:06 PM   #12
Master Electrician
That should be understood. It's the same with a single switch. If you turn a switched receptacle off it wont work either.
Old 07-07-2011, 03:15 PM   #13
This installation is two single switches on either end of the room controlling the light and fan simultaniously. The remote holder mounts over the switch preventing you from using it. So if I buy two remotes and program them to the same controller( and leave the swithes along) I should be able to controll the fan and light with either remote.
Hunter remote #27144.
I am getting ready to try it .......I'll let you know the outcome>
Bob
Old 07-11-2011, 08:40 PM   #14
I tried it and it doesn't work. I use one remote to control multiple fans but I can't program two remotes to control the same fan. I would like to find a way to clone the remote control.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
How can I install a power switch on my compressor? sofasurfer Electrical 1 09-27-2010 04:04 AM
Wireless Switch indy Electrical 9 12-07-2009 06:10 PM
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 09:46 AM
Thermostat w/ wireless Remote Sensor Davidb6 HVAC 2 02-10-2009 08:45 PM
