Can I Install A Circuit Breaker Above The Master Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 03:01 AM   #1
Can I install a circuit breaker above the master breaker?
I recently moved into a new house. I need to add a circuit breaker to the breaker box, but the master breaker isn't located at the very top of the power strips. There is enough space for two more breakers above the master.
If I install a breaker above the master breaker will it work? Is there any reason an electrician may have placed the master toward the center of the power strips?
bigdog123 is offline   Reply With Quote
Old 09-15-2011, 03:34 AM   #2
Code05's Avatar
Rewards Points: 1,104
Is this a back fed panel? Got a picture?
Code05 is offline   Reply With Quote
Old 09-15-2011, 03:49 AM   #3
Rewards Points: 1,192
Split bus . You are allowed 6 disconnects.Yes.
bobelectric is offline   Reply With Quote
Old 09-15-2011, 05:16 AM   #4
Code05's Avatar
Possible yes, but OPs description is too vague for to say it is a split buss.
The Following User Says Thank You to Code05 For This Useful Post:
NJMarine (09-15-2011)
Old 09-15-2011, 01:27 PM   #5
Anything useful here? The link is to a photo of the breaker box. http://s652.photobucket.com/albums/u...breakerbox.jpg
Old 09-15-2011, 03:06 PM   #6
Code05's Avatar
Why do I think I am looking at a Zinsco panel?
gregzoll (09-15-2011)
Old 09-15-2011, 03:51 PM   #7
Rewards Points: 6,652
http://www.ismypanelsafe.com/zinsco.aspx
Hope you have your hot dogs and marshmallows ready.
Old 09-15-2011, 03:53 PM   #8
Code05's Avatar
Old 09-15-2011, 06:00 PM   #9
Electrical Contractor
kbsparky's Avatar
That looks like a ZINSCO combination meter/service panel box.
I'd suggest replacing the whole thing, if you can.
-KB
Old 09-15-2011, 06:03 PM   #10
Code05's Avatar
Old 09-15-2011, 06:45 PM   #11
Sparky
Rewards Points: 510
think... good one.
Techy is offline   Reply With Quote
Old 09-15-2011, 11:15 PM   #12
Okay so I gather Zinsco Panels have a bad reputation. I'm renting and I'm not about to replace an entire breaker box. Whats the story on these? Oh, by the way, I added two breakers above the master and they both work just fine. Thanks for addressing the question.
Old 09-16-2011, 12:39 AM   #13
Semi-Pro Electro-Geek
Rewards Points: 2,920
If you're renting, you definitely shouldn't be doing electrical work. Especially with that panel. The breakers are well known for completely refusing to trip under any fault conditions, even with the wires melting and catching on fire. The breakers also develop loose connections to the bus that cause fires. I would suggest that you complain to your landlord and ask that it be replaced. It really should be.
mpoulton is online now   Reply With Quote
Old 09-16-2011, 01:59 AM   #14
" Euro " electrician
frenchelectrican's Avatar
I type in bold which that is a rental place you should done in first place is talk to your landlord first.
Second thing many of us Electricians are not too crazy with Zinsco or FPE one of the two is the top two worst one on resdentail side. { there is no Conneries on this one }
I did save one veido which it was on the youtubé which it did show the Zinsco breaker actually did NOT trip on 50 amp load on 20 amp breaker so again that is no conneries on this one as well.
If ya don't belive it just let me know I will post it for ya.
Merci,
Marc
Old 09-16-2011, 09:26 AM   #15
Rewards Points: 91
Sounds like...I'll ask the question but if I don't like the answer....I'm doing it anyway!
George6488 is offline   Reply With Quote
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Circuit Breaker Question Bob Deb Electrical 15 11-29-2010 07:34 PM
Circuit breaker question kupalino Electrical 6 12-18-2009 11:35 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
