Can I Hook Up A Regular Electric Drill To A Dimmer Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 12:06 AM   #1
Maker of Stuff
Can I hook up a regular electric drill to a dimmer switch?
That should read FAN CONTROL , not dimmer,
Hi there. I searched the forums and found nothing so here goes.
My wife thinks I'm going to kill myself and/or burn down the house if I cut off the plug from a Black & Decker drill and hook it up to a fan control switch (not a dimmer) switch. I'm confident that all I have to do is take one wire and hook it up in the same way the instructions say for a fan.
i'm building a pickup (i.e. electromagnet) winder so a variable speed drill won't work. I need to be able to control the speed externally. The drill will be mounted on a board with the pickup in the chuck with magnet wire being fed onto it.
Am I out to lunch? Should I up my life insurance? Or is this safe, given a certain amount of safety consciousness and precaution?
I have attached pictures of the drill, the fan switch, the fan switch box, fan switch instructions and a sketch of my idea.
A quick answer would be really appreciated!
Last edited by nicholaspaul; 12-01-2011 at 01:53 AM. Reason: I meant fan control, not dimmer.
nicholaspaul is offline   Reply With Quote
Old 12-01-2011, 12:07 AM   #2
Maker of Stuff
Oh yea, and could you also (sorry) let me know what your qualifications are and your experience? Yes, I have to cite references....Thanks for humouring me!!
Old 12-01-2011, 12:24 AM   #3
DIY staff
Rewards Points: 7,174
An electrician will be along shortly---But you miss spoke a bit---a dimmer would not work --but a fan speed control should--
You pictured a fan speed control --Is that what you have?
Why not add that to a double electric box with a cord and wire it to an outlet ? Then plug the drill into
the outlet---
A licensed electrician will be right along---
Old 12-01-2011, 12:27 AM   #4
Maker of Stuff
the outlet---
Thanks Mike! Yes, I misspoke. It is a fan speed control I have, NOT a dimmer (emphasis on the not...!) A quick Google told me not to use a light dimmer.
I could do the double box idea. I'm not planning on using the drill for anything else (the POS!) so permanently wiring it this way is fine for me.
Old 12-01-2011, 04:54 AM   #5
dmxtothemax's Avatar
Rewards Points: 5,096
It will not work !
Electronic type motor speed controllers are made for
induction type motors.
But most electric drills use a universal type motor.
You will have to find a electronic speed control
suitable for a universal motors.
They are out there, just not as common.
dmxtothemax is offline   Reply With Quote
Old 12-01-2011, 06:32 AM   #6
DIY staff
Back to the drawing board---
Old 12-01-2011, 06:50 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
They are actually VERY common.
http://www.amazon.com/Router-Power-T.../dp/B0012WKCXK
Old 12-01-2011, 07:24 AM   #8
Just curious how old is this drill??? Nearly all drills sold nowadays are variable speed.
If the dimmer is designed for inductive loads(fans), and the load(drill) is less than the dimmer rating, usually 600W(5A), it willl work.
Old 12-01-2011, 09:09 AM   #9
Meep!
Joe Dirt's Avatar
That does look like a new drill... We have some similar units for our routers at work (router speed controls)
Just curious- wouldn't it be a whole lot easier and faster to just go get a $15 variable speed drill, then build that type of unit and carry all of that stuff around?
Joe Dirt is offline   Reply With Quote
Old 12-01-2011, 10:22 AM   #10
Mad Scientist
It sounds like he just wants to use the cheapo drill as a motor for winding coils, which is why he wants an external and easily adjustable speed control.
McSteve is offline   Reply With Quote
Old 12-01-2011, 11:02 AM   #11
liscenced electrician
Rewards Points: 538
A while ago I needed to slow down my angle grinder for polishing some granite. I stuck a normal dimmer switch in a 2g box with a receptacle and a cord. Had no idea if it would work but it worked beautifully (the dimmer, not the polishing job)
jimmy21 is offline   Reply With Quote
Old 12-01-2011, 11:09 AM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD IT RIGHT THERE !
The OP clearly stated:
... could you also (sorry) let me know what your qualifications are and your experience? Yes, I have to cite references...
And none of you guys have posted your resumes so far. "F"
Old 12-01-2011, 03:02 PM   #13
Maker of Stuff
Thanks Pete- for only $25 I can keep everyone happy!
That drill is brand new. Believe it or not B&D still sell single speed drills . I did actually state that a variable speed drill won't work because it has to be mounted and run at a constant speed
Old 12-01-2011, 03:45 PM   #14
Maker of Stuff
The drill is rated 3A and the switch is 5A. So you think i'm good to go? :D (Fishing for permission here!)
Old 12-01-2011, 05:10 PM   #15
The problem is that most drills are not induction motors !
They are mostly universal motors (different).
So you need a speed control made for universal motors,
not a control made for induction motors !
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Dimmer switch burned out my fan lights?? Dannery Electrical 1 09-14-2011 09:58 PM
fitting a dimmer switch jayh Electrical 6 11-26-2010 01:40 AM
Dimmer switch wiring question joez148 Electrical 2 07-15-2010 11:49 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
