Can I Have GFCI Outlets On Same Circut As Normal Outlets? 12/2 - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 01:46 AM   #1
Rewards Points: 143
Question
Can I have GFCI Outlets on same circut as normal outlets? 12/2
Hi everyone, I am looking a few books and they all show samples of circuits but never tell or show if you can mix outlet types.
I have a circuit running to 2 bedrooms for my power outlets. The are on 12/2 and a total of 6 outlets. I wanted to add 2 GFCI outlets for the deck outside and wanted to know if it was ok to add those outlets to this circuit since I can still add 4 more outlets?
Can't seem to find sample diagrams.
cloves is offline   Reply With Quote
Old 05-06-2013, 05:48 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It is fine.
Old 05-06-2013, 06:45 AM   #3
JW
mm11's Avatar
Rewards Points: 614
In residential, there's no limit to the number of receptacles on a circuit. You could have 20 duplex receptacles, or more, on the same circuit and be compliant with the NEC.
mm11 is offline   Reply With Quote
Old 05-06-2013, 07:20 AM   #4
Rewards Points: 1,512
There are some restrictions on what branch circuits can serve what, but a circuit serving bedrooms may also serve an outide deck.
Depending on the exact wiring, optionally one ground fault interrupter unit can serve both deck receptacles.
To accomplish the latter, one of the outlet boxes must be downstream of the other in the usual daisy chain and also the circuit must not be a multiwire branch circuit typically using red and black hot wires sharing the neutral. Install the GFCI unit in the more upstream of the two outlet boxes and connect both black and white of the continuing cable to its "load" terminals instead of wire nutting pigtails to the "line" terminals.
Old 05-06-2013, 11:26 AM   #5
Special User
Rewards Points: 1,230
Indeed. You can even GFCI-protect bedroom receptacles if you wish; it's not required, but it is allowed.
Since you have 12ga wire you can also mix 15A and 20A receptacles if you wish.
Note if you are in Canada I think there's a limit to the number of receptacles on a circuit... no problem in the US though.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-06-2013, 10:57 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
GFI's function fine on MWBC ...at least downstream of the mwbc breeak...maybe upstream... never was an issue for me as generally they break into two circuts at the first box...is there something I'm mistaken about,???? I'm not a sparky.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-07-2013, 05:09 AM   #7
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
NOT TRUE !!!
Section 220-3(c)(6). The NEC does not have a specific rule that says 10 receptacles on a 15 ampere circuit or 13 receptacles on a 20 ampere circuit. For 15 ampere circuits, the calculation is as follows: 120 volts x 15 amperes = 1800 VA/180 VA = 10 receptacles, and for 20 ampere circuits, 120 volts x 20 amperes = 2400 VA/180 VA = 13 receptacles.
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-07-2013, 05:19 AM   #8
Licensed electrician
Rewards Points: 1,622
Article 220 deals with how to size the service.
The number of receptacle on a circuit does not apply to residential work.
Old 05-07-2013, 05:23 AM   #9
Rewards Points: 516
Article 220-Branch Circuit, Feeder and Service Calculations
Old 05-07-2013, 05:24 AM   #10
Rewards Points: 345
Originally Posted by k_buz View Post
It is fine.
This is really the only answer that was necessary.
al_smelter is offline   Reply With Quote
Old 05-07-2013, 05:26 AM   #11
Rewards Points: 516
and since we are CALCULATING Branch circuits ...... 180va per outlet ...
Old 05-07-2013, 05:28 AM   #12
Rewards Points: 516
I was replying to that statement ..... In post # 7
Old 05-07-2013, 05:37 AM   #13
In order to continue GFCI protection downstream from a GFCI receptacle (load terminals) on a MWBC that also continues, you need to run a separate 2 conductor cable for the protected subcircuit.
You can have any number of separate GFCI units on the MWBC, connected via their line side terminals (subject only to the limit of total number of units or devices of all kinds).
(rarely seen) When the MWBC breaks into two (non-MWBC) subcircuits at a box, you would need a third subcircuit for continuing the GFCI protection if you also want both halves of the MWBC to continue downstream without protection.
The GFCI load side neutral and the line side neutral may not be bonded together (interconnected using any combination of additional wires or components). Same for the load side hot and any line side hot.
Old 05-07-2013, 06:35 AM   #14
jbfan's Avatar
Rewards Points: 478
220.14(J)
Outlets specified in (J)(1),(2), and (3) are already included in the general lighting load of 220.12. No additional load calculations shall be required for such outlets.
As many receptacles as you would like to have on a general use circuit in residential.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Jim Port (05-07-2013)
Old 05-07-2013, 06:49 AM   #15
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Only for "other outlets".
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Piggy Backing Off GFCI Outlets miamicuse Electrical 20 06-05-2012 09:55 PM
Breaker Panel Replacement Plan jillers Electrical 24 01-28-2012 10:12 AM
OK to run one GFCI + 4 standard outlets from a junction box? Fulg Electrical 6 12-04-2010 11:43 PM
GFCI Outlets in Basement helpless handyman Electrical 4 04-20-2008 10:23 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
