Can I Easily Replace My Old Basement Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 05:16 PM   #1
Can I easily replace my old basement lights?
Hey guys,
I want to replace my basement lights with can lights. The house is 35 years old, can I simply just swap out the lighting without worry of amps / volts?
Also what If I wanted to add a few extra? Can I just add another wire from the previous light to the new one?
vexious is offline   Reply With Quote
Old 12-02-2012, 06:19 PM   #2
Rochsolid's Avatar
Originally Posted by vexious
Hey guys,
Yes you can remove your old lighting and use that feed for your new pot lights. You can only put 12 lights on a 15 amp circuit
Rochsolid is offline   Reply With Quote
Old 12-02-2012, 06:33 PM   #3
Licensed electrician
Rewards Points: 1,872
Your recesed will most likely call for 90 degree C rated insulation.If you have NM cable it must be NM-B.
The NEC does not have a 12 light limit on 15 amp circuits. The circuit is based on the maximum wattage of the bulb that could be installed, not what is actually installed.
Old 12-02-2012, 07:41 PM   #4
Originally Posted by Jim Port View Post
Your recesed will most likely call for 90 degree C rated insulation.If you have NM cableit must be NM-B.
Jim, can you explain in idiot terms? haha thanks.
Old 12-02-2012, 08:14 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,604
Most light fixtures have a maximum rating,
lets say for now its 100w.
If you have 12 lights, thats 12 x 100 = 1200w.
Your circuit must be able to safely supply this.
Even thou you might only use 60w lamps.
Cause at a later stage someone could easily
replace the lamps with 100w not knowing any better.
Its known as idiot proving.
dmxtothemax is online now   Reply With Quote
Old 12-02-2012, 08:39 PM   #6
The post above mine stated a limit of 12 fixtures from the CEC. The US uses the NEC which does not have the same rule.
DMX explained sizing the circuit.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 07:10 AM
Commercial Electric Pot Lights in Insulated Basement Ceiling balithecat Electrical 4 03-14-2011 05:46 PM
basement wiring plans for lights JonnyG Electrical 10 04-05-2009 05:46 PM
3-way lights in basement johnson217 Electrical 1 06-01-2005 06:18 AM
