-   -   Can I easily replace my old basement lights? (http://www.diychatroom.com/f18/can-i-easily-replace-my-old-basement-lights-165398/)
vexious 12-02-2012 06:16 PM
Hey guys,
I want to replace my basement lights with can lights. The house is 35 years old, can I simply just swap out the lighting without worry of amps / volts?
Also what If I wanted to add a few extra? Can I just add another wire from the previous light to the new one?
Rochsolid 12-02-2012 07:19 PM
Originally Posted by vexious
Hey guys,
Yes you can remove your old lighting and use that feed for your new pot lights. You can only put 12 lights on a 15 amp circuit
Jim Port 12-02-2012 07:33 PM
Your recesed will most likely call for 90 degree C rated insulation.If you have NM cable it must be NM-B.
The NEC does not have a 12 light limit on 15 amp circuits. The circuit is based on the maximum wattage of the bulb that could be installed, not what is actually installed.
vexious 12-02-2012 08:41 PM
Originally Posted by Jim Port (Post 1065115)
Your recesed will most likely call for 90 degree C rated insulation.If you have NM cableit must be NM-B.
Jim, can you explain in idiot terms? haha thanks.
dmxtothemax 12-02-2012 09:14 PM
Most light fixtures have a maximum rating,
lets say for now its 100w.
If you have 12 lights, thats 12 x 100 = 1200w.
Your circuit must be able to safely supply this.
Even thou you might only use 60w lamps.
Cause at a later stage someone could easily
replace the lamps with 100w not knowing any better.
Its known as idiot proving.
Jim Port 12-02-2012 09:39 PM
The post above mine stated a limit of 12 fixtures from the CEC. The US uses the NEC which does not have the same rule.
DMX explained sizing the circuit.
