Old 01-28-2013, 09:33 PM   #1
Can I do this myself.
Putting the final touches on my basement plan to submit for permit.
This is part of my code i need to follow.
(A) All wiring systems which carry 110 volt or larger shall be installed in rigid pipe, Intermediate metallic conduit (IMC) or Electric metallic tubing
(EMT).
If i was just running Romex i would be comfortable but i have never dealt with metal conduit.
What is the learning curve and is it worth my time learning or hiring someone?
I will have about 30 outlets, 5 switches and 15 can lights to be installed.
ryanmcl is offline   Reply With Quote
Old 01-28-2013, 09:37 PM   #2
Licensed Electrician
k_buz's Avatar
Where do you live that this is required? The only place I know of with such a code is Chicago.
Location...Location...Location
Old 01-28-2013, 09:46 PM   #3
I am just north of the city of Chicago.
Old 01-28-2013, 09:48 PM   #4
k_buz's Avatar
Buy LOTS of couplings.
Old 01-28-2013, 10:02 PM   #5
Field Service
(EMT).
I did my basement in EMT; whether you can do it or not, can't really say. It's all about getting good with a pipe bender, or buying pre-fab bends. You'll make some mistakes, but I picked it up pretty quickly. If you need it in a hurry hire a pro; it's unbelievable how quickly they can put the stuff up. It will take you MUCH longer.
diystephen is offline   Reply With Quote
Old 01-28-2013, 10:06 PM   #6
Did you run it through the wall studs? Also what did you cut them with? I have all the time in the world.
Old 01-28-2013, 10:12 PM   #7
Master Electrician
And lots of pipe. Learning curve for pipe bending.
brric is offline   Reply With Quote
Old 01-28-2013, 10:16 PM   #8
Field Service
Yep, ran through the studs for outlets, and across joists (drop ceiling) for lighting. I have access to a bandsaw, and found that it worked incredibly well for EMT. You can also use MC for short runs (I believe it's up to 3', but may be 6'.) MC is great for lighting (and necessary in a drop ceiling with pot lights.) I used the 3' rule when I did my lighting, but I was asked about that recently on the forum and am waiting for clarification from my electrician buddy.
Old 01-28-2013, 10:19 PM   #9
What was the longest piece you could fit through the studs in one shot? 6ft?
Old 01-28-2013, 10:24 PM   #10
Electrician
Pipe work is an art, it takes time to get good and fast. I always tell apprentices not to worry to much about time but learn the bends and the speed will follow. Running pipe is probably the most enjoyable part of the job for me.
Look at youtube I am sure there is videos there to help you out.
darren is offline   Reply With Quote
Old 01-28-2013, 10:34 PM   #11
Field Service
I put up studs, and ran conduit at the same time; much easier I like a lot of outlets, so they're every 8' (with a solid piece of EMT between.)
Old 01-30-2013, 10:12 PM   #12
How big of pipe did you go with? 10ft x 1"?
Old 01-31-2013, 01:34 AM   #13
" Euro " electrician
frenchelectrican's Avatar
The size of pipe most case useally 3/4 or 1/2 inch EMT depending on the layout for most of the home runs useally 3/4 inch most case but once a while half inch home runs and the numbers of conductors in the conduit.
I can use either 6 or 8 feet stick depending on the way the stud is bored out and the layout and size of conduit.
BTW ( by the way ) Chicago do have it own unquine colour format I will try to post what the colours and what it functions it means.,
Black , Red , Bleu - power source ( useally unswitched )
White - Non GFCI or Non AFCI netural
Grey - GFCI or AFCI netural
Orange or Yellow - switched source
Brown - traveller for three/four way switches ( common colour but some case other will show up.
Purple - useally GFCI or AFCI source *
* please verify your area it may change the colour format some way so be aware if any change do show up.
Merci,
Marc
