Can I Disconnect A Gas Fireplace Blower? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 08:01 AM   #1
Question
Can I disconnect a gas fireplace blower?
I mavoed into a home with a direct vent gas fireplace. It has a blower that comes on when the fireplace heats up. The blwer is too loud and I don't need that much heat in the room. Can I simply disconnect the blower? Are there risks to doing so?
davidm is offline   Reply With Quote
Old 10-03-2009, 08:49 AM   #2
Possibly, the fan blows air across the heating chamber, cut off that airflow and you could have overheating. The heater apparently is strictly forced air, not radiant. Don't try and change its' design.
Old 10-03-2009, 09:58 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,288
Are you sure there is not a fan speed control with off setting for the blower?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Installing Dimmer for fireplace blower MountainMan HVAC 4 07-03-2008 12:09 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
