Old 10-11-2010, 05:16 PM   #1
can I cut a metal gang box?
I need to mount a new metal gang box in my wall (I need to make it a double instead of a single)
the wall is wood paneling, so I can't just cut a bigger hole a putty it, would it be breaking code to cut back half an inch or so of the outside lip of the box so I can fit a drill bit up and in there to screw it to the 2x4 or does putting that small hole in the metal box void it?
I need to use the metal box for grounding reasons.
MLMIB is offline   Reply With Quote
Old 10-11-2010, 05:41 PM   #2
nap
You talking to me?
nap's Avatar
dang, I can't find the section in the code but basically, when mounting a box in a flammable material (like wood paneling) the box must be flush with the face of the wall. sounds like you need an old work box aka cut in box. Here is one type. Many of them (including this type) is gangable so you can put 2 or more together to make a 2 gang (or larger) box.
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 10:46 AM
How to drill through metal in headers Docfxit General Discussion 5 07-05-2009 11:31 PM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 01:21 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
