Can I Convert A Screw Base To A 2 Or 4 Pin Base? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 08:16 AM   #1
Can I convert a screw base to a 2 or 4 pin base?
I have a Zadro Fluorescent light wall mounted magnifying make-up mirror with a screw in bulb FB13WR 120V/60Hz BUT CANNOT FIND replacement bulb. Can be 25W Type T Bulb or 9w/13w Fluorescent.
So, I am wondering if I can screw something in to convert female base to a female base for a pin based fluorescent light bulb. Please help me!! Signed, a frustrated woman trying to put makeup on!! Or, if you know where I can purchase bulbs...please tell me.
DeniB is offline   Reply With Quote
Old 10-23-2010, 08:45 AM   #2
the Musigician
DangerMouse's Avatar
Here you go.... now go do that makeup! ( as if you really need it! ) Po)
http://www.bedbathandbeyond.com/prod...paign=shopping
DM
Old 10-23-2010, 08:58 AM   #3
the Musigician
Although, after reading a few reviews, I wonder if they're even in business any more?
I.E.: Poorly Engineered
Started Dec 2, 2007
I work for a major high end hotel. We purchased several hundred of this type of mirror. After a few months the glass started falling out of the mirror. I was told this is because they are being used in a humid environment (bathroom). The hinges also loosen up while moving, this causes the mirror to sag. The final problem we encountered was that a guest shocked themselves due to the wire inside shorting out caused by chaffing. Poor customer serves fails to deal with the problem. I do not recommend this product to anyone!
Also: Replied Jan 3, 2008
I agree. While my glass has not come out, the bulb failed after about 365 hours of use (1 hr/day for a year). It is rated 8,000 hours! Does anyone know where to find a replacement. It is an oddball bulb, a 13W 2 tube CF type with candelabra base. The only thing printed on it is FB13WR 120V/60Hz. I can't find one anywhere. Tried local electrical suppliers as well as Home Depot and the Internet. No luck.
Reviews like these would shy me away from them to begin with.
DM
Old 02-01-2012, 01:52 PM   #4
I think I can actually help on this one!
I have a few of these mirrors at rental properties and I could not locate any replacement bulbs anywhere. I came across this company called Interlight when searching the web..
I have ordered a few times from Interlight and I received the bulbs about 2 days after my order was placed. The bulb was the exact same as the original that came with the mirror
Hope I helped !
agray34 is offline   Reply With Quote
How to convert a pin-base CFL socket to a screw base socket in can light? minh Electrical 11 09-06-2010 07:35 AM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
convert plug in light with screw in hornet1946 Electrical 5 01-31-2008 06:00 PM
