Can I Connect A Three Way Switch To A Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 03:38 PM   #1
Can I connect a three way switch to a single pole switch
I have two three way switches that control a light overhead. I'd like to put a single pole switch in the same receptacle that houses one of the three way switches in order to control a different light. The power would come from the wires into the three way switch. Can it be done?. I've tried different combinations but either the circuit breaker kicks off, or the three way switch lights don't work, or nothing works.
handicap9 is offline   Reply With Quote
Old 11-30-2011, 03:56 PM   #2
Licensed electrician
Rewards Points: 1,634
You would need to have the power feed in the box where you are trying to add the new switch.
Old 11-30-2011, 06:29 PM   #3
joed's Avatar
Rewards Points: 12,950
You need to tell us all the wires in the switch box.
If there are only three wires then you can't do it. There is no neutral wire.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 08:41 PM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 08:51 PM
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 06:03 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
