Can I Connect Different Gauges Of Wires ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 02:49 PM   #16
Rewards Points: 3,396
Originally Posted by kennykenny View Post
I am not familiar with these connectors. Are they just like butt connectors which you just crimp the ends?
No crimp.
See the allen key.
ritelec is offline   Reply With Quote
Old 06-12-2014, 07:45 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They are set screws with a heat shrink sleeve. I do a LOT of landscape lighting, and this is all I use.
Old 06-12-2014, 09:59 PM   #18
Rewards Points: 672
So with the Ace Connectors, I can put the smaller wire in one end of the connector and the larger gauge wire goes in the other end and then heat shrink the cover over the top of it?
Can this be purchased at Lowes and/or Home Depot? I can't find it on their web sites.
kennykenny is offline   Reply With Quote
Old 06-13-2014, 02:31 PM   #19
Rewards Points: 672
Thanks to everyone, I now know the connectors to use for my wiring. My next question is what is the correct order to wire it up.
When I cut the 14 gauge wire apart and separate them, on both sides, I will have 4 separate wire leads. I will also have the two wires from my low voltage light. How are these to be connected together----3 and 3? One wire from the light, one from each side of the 14 gauge wire(the matching side that was just cut)? And do this on both sides of the wire? Thanks!
How do you connect tiny 12 volt wires together? kmc Electrical 8 05-27-2012 10:39 PM
How do I connect these two sets of wires? Shpigford Electrical 5 05-27-2012 06:29 PM
Running wires alongside or through ductwork j_sun Electrical 1 07-13-2011 11:11 AM
How to connect ground wires? Iva Electrical 3 10-29-2010 12:13 PM
