Can I Bury An Ethernet Cable In A Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 09:14 AM   #1
Rewards Points: 211
Can I bury an ethernet cable in a wall?
I have an unsightly coax/ethernet combo wall plate, in which the ethernet cable is connected into the wall plate. I've just put up beadboard wainscoting in my child's nursery and want to get rid of the ugly faded wall plate. I have no futher need for the ethernet cable b/c my whole house is wireless. Can I just cut the ethernet cable and tape and cap it and bury it in the wall? It's low voltage right? I appreciate the help!
gtothek is offline   Reply With Quote
Old 02-27-2013, 09:27 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
That's not a problem.
Old 02-27-2013, 09:57 AM   #3
Rewards Points: 736
Why not disconnect the other end too, just for good measure? Not because of any electrical worry, but ... I dunno, why have a big antenna coming off your router when you don't need to?
TheBobmanNH is offline   Reply With Quote
Old 02-27-2013, 11:37 AM   #4
Rewards Points: 211
The ethernet cable is running up 2 floors from my basement. I don't have the patience or know how to snake it all the way out. I'm not sure what you mean by big antenna off the router.
Old 02-27-2013, 11:48 AM   #5
Rewards Points: 736
Wasn't saying to pull it out of the wall, just to disconnect the other end from the router.
Old 02-27-2013, 12:35 PM   #6
antennae
in terms of signal propagation, the cut end of a cable that is still connected to active equipment, the line becomes an antenna broadcasting all signals sent thru the router. while you may think this is in itself convenient it posses security concerns (that likely wouldn't affect a typical household) and may produce electromagnetic interference with other radio frequency devices like baby monitors in some cases. cutting both ends is best and tag each to indicate the location of the other end, ie. at the router end label the cut end as 'baby's room' and in the baby's room label it as 'to router'. in the future this may be reused by the next tenant of the house or perhaps your child if a wired connection is ever required (wired is still the most stable and reliable).
Cicatrix is offline   Reply With Quote
Old 02-27-2013, 12:46 PM   #7
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Slightly off-topic, wired is way-faster than wireless too. Great wireless right now is 150Mbps. Wired is over 1000Mbps. Like Cicatrix said, you may want to hook that back up in the future for some application that wireless just doesn't have the bandwidth to do well (1080p video streaming, for example). I'd just neatly tuck it into the wall and remember where it is, then unhook the other end from the router and keep it there for a future date. It won't hurt anything just sitting in the wall unhooked.
hyunelan2 is offline   Reply With Quote
Old 02-27-2013, 01:31 PM   #8
Rewards Points: 211
The other end of the ethernet cable in my basement is not connected. The previous homeowner had every room in the house hardwired and plugged into a hub in the basement. I just unplugged the hub and have the whole house running wireless. I will leave the cut ethernet cable buried in the wall, if I ever need to use it in the future.
Old 02-27-2013, 02:04 PM   #9
Rewards Points: 736
Kind of funny that you were worried about it being "low-voltage" then. if neither end is hooked up, it's no voltage.
Old 02-27-2013, 02:36 PM   #10
Rewards Points: 211
Haha I kind of came to that realization while reading the replies on this post! D'oh!
Old 02-27-2013, 07:49 PM   #11
Rewards Points: 6,652
Never going to happen in a million years with ethernet cabling. Now of course, in most places, you would use a patch panel and just disconnect the patch cord to the unused jack, but other times, you leave it alone, and nothing happens with the cable being always connected to the switch, which would then be connected to a router, then to a firewall, then to a modem.
This is the funniest thing I have ever heard in my life, of dealing with networking & computers in over 35 years.
The Following User Says Thank You to gregzoll For This Useful Post:
daveplot (02-28-2013)
Old 02-27-2013, 08:11 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,902
I disagree with that. The unterminated end is certainly an impedance mismatch and will cause high SWR at the driving end (which is not harmful in any way for an ethernet port). However, it is still a twisted pair cable with differential signaling. There should be no more radiation from the cable than if it were properly terminated. This is not like coax or ladder-line, which can radiate if not terminated properly.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-27-2013, 08:15 PM   #13
Rewards Points: 1,016
If you leave it connected to the router and just cut off the other end, all the bits will fall out of the router through the open cable end.
To prevent this, just tie a knot in the end of the cable where you cut it off.
____________
Vince
The Following 4 Users Say Thank You to vsheetz For This Useful Post:
gregzoll (02-27-2013), Hardway (02-27-2013), jbfan (02-28-2013), Speedy Petey (02-27-2013)
Old 02-27-2013, 09:29 PM   #14
Or place the end into a bucket and when it gets full, empty it out.
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
