Old 08-04-2010, 01:30 PM   #1
Can I add a new ground bar on relocated panel?
In preparation for a basement finishing, I had my licensed electrician move my panel away from the service entrance. To meet code (distance from entrance to shutoff), he had to install a main shutoff outside, then run the cable to my relocated box (and which also has it's own main shutoff).
Last night, when preparing to run two new circuits, I found that he ran all of the grounds in the relocated box to a single grounding bar on the left. I want to add circuits on the right, and don't want to run the wires all the way down, over, up to the left grounding bar.
Can I add a new grounding bar on the right? There are pre-drilled holes for it. Do I need to connect to the existng ground bar, or will the screws attached to the metal case accomplish that?
Thanks,
toddmanqa
toddmanqa is offline   Reply With Quote
Old 08-04-2010, 01:51 PM   #2
Mad Scientist
You can indeed add a second ground bar. I did the same thing with my garage sub-panel, and for the same reason. Home Depot or whatever should carry an add-on ground bar for your panel, if it's a fairly recent or common one.
Remember that your panel is now a sub-panel, so make sure you keep your neutral and ground wires on their own separate bars.
McSteve is offline   Reply With Quote
Old 08-04-2010, 01:53 PM   #3
Electrician
Proby's Avatar
May I ask why you don't want to run the wires to the left side ground bar?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-04-2010, 02:41 PM   #4
In regards to why I don't just run to the existing ground bar, it's getting a little crowded there and I'll be saving wire by staying on the same side of the box that the wires are coming into.
Thanks for the responses.
toddmanqa
Old 08-04-2010, 08:57 PM   #5
Went to Lowes and found the necessary square d home grounding bar. The instructions called for me to drill two holes with a #26 drill bit to attain 0.147 in (3.7 mm) in diameter. I found a 9/64" Dewalt Cobalt Drill bit. It was only 3.6 mm in diamter, but the screws went right in nice and tight.
Turned power back on after adding the circuits and the two new circuits checked out OK with the GFCI tester.
Old 08-04-2010, 09:14 PM   #6
Electrician
Proby's Avatar
Good, glad it worked.
Out of curiosity, why did you drill holes? You mentioned earlier that your panel had pre-drilled holes.
Tags
bar, ground, grounding, panel, relocated
Main Panel / Service Upgrades gbe Electrical 12 11-07-2009 12:20 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
THHN for ground to sub panel nprranch Electrical 1 12-23-2008 01:35 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
