Can I Add A 220V In This Garage Sub Pannel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2015, 11:20 AM   #1
Rewards Points: 20
Can I Add a 220V in this garage sub pannel
I bought a 220V welder and want to add a circuit to the sub panel in my garage.
At the main box, the feed going to the garage is 220v with 10 guage wire. Currently there is a dp 20 Amp Breaker, but i will upgrade this to a 30 Amp.
In the Garage, this is what the box looks like. it is a Cutler-Hammer. Problem is, i don't space for another breaker. Do i have any options?
I can maybe envision that if i got 4 skinny breakers, the two outside ones could go to the existing circuits and the 2 inner ones (presumably one going to each leg) with the handles tied could be the 220v circuit?
Or will i need to get a new sub panel box?
ms14 is offline   Reply With Quote
Old 01-19-2015, 12:16 PM   #2
Rewards Points: 144
How many amps are feeding into the garage?Spme welders call for 50-60 amp circuits.
What does the welder require?
mako1 is offline   Reply With Quote
Old 01-19-2015, 01:02 PM   #3
Rewards Points: 20
Welder needs a 20 Amp breaker
Old 01-19-2015, 01:41 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Couple things ..
The current sub-panel is improperly installed which has to do with neutral ground bonding requirements. It appears it is a 3 wire feeder unless the conductors are in metal conduit. If it is a 3 wire feeder in pvc conduit you need to install the bonding means you see on the back of the box. Could also be non compliant period if the sub is in an attached garage as you need a 4 wire feeder with neutral and ground separated.
You can't add any breakers to that panel unless the labeling says it is a 4 circuit panel. In that case skinny/tandem breakers can be added.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-19-2015, 05:47 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,858
If the panel is labelled for 4 circuits, then you can use a "quad" breaker that has the center two handles tied together. They are available with many different amperage combinations, but in this case a 20/20/20/20 would be the way to go.
As Stubbie said, the three-wire feeder is only allowable here if it was installed quite some time ago, or if there is a metal bonding path back to the main panel separate from the neutral conductor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 01-19-2015, 05:50 PM   #6
Rewards Points: 20
Thanks for the info!
Yes, the conductors do come in through a metal conduit and yes, it is a detached garage.
I will look for the labeling tonight, I'm not optimistic that it will be there though.
Old 01-20-2015, 01:09 PM   #7
Rewards Points: 20
So definately no labeling on/in the panel.
Old 01-20-2015, 01:11 PM   #8
Rewards Points: 20
From the looks of it, i don't see how a quad breaker (or double 220v) breaker would go in here, there is this plastic septum thing seperating the two legs.
Looks like a new panel i guess
Old 01-20-2015, 09:37 PM   #9
Rewards Points: 3,396
Replace it with a 8 circuit or so panel
ritelec is offline   Reply With Quote
Old 01-20-2015, 09:41 PM   #10
Either the quad breakers for that panel have a slot to accept the "septum", or that exists to prevent you from installing a multipole breaker in that panel.
Old 01-20-2015, 09:41 PM   #11
metal conduit.........is the whole run metal that you can see, or maybe just where it comes out of the ground and it's pvc only.?
3 wire to a outbuilding was permitted at one time. wondering if you change the panel would you be required to bring the ground out too..
Old 01-20-2015, 09:43 PM   #12
Could also install a 60 two pole there and feed a separate 8 circuit or so sub panel and make that your main breaker
Old 01-20-2015, 11:24 PM   #13
Usually Confused
lenaitch's Avatar
Rewards Points: 442
Re Ritelec's suggestion of another downstream sub panel, are there any Code/safety/practical implications of having a breaker protecting a breaker protecting a breaker? Or like other things in life (!?) is there no such thing as too much protection?
lenaitch is offline   Reply With Quote
Electrical Wiring for Separate Garage HomeGuy2 Electrical 11 03-15-2013 11:50 PM
220V 15A outlet in Garage curiousB Electrical 97 01-27-2012 10:53 PM
220v service for garage chevelle Electrical 2 11-11-2011 06:23 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 07:47 PM
